Results 1 to 5 of 5
Thread: Start up idles
    Feb 2024
    Clinton, Mississippi
    29
    Start up idles
    I want to adjust my idle tables, this will sound wierd for sure but when ambient temprature is 60-100 degrees the cold start up idle is like 1300 rpm for about a minute. And when ambient temprature is 50-20 degrees the cold start up is around 900 rpm which I don't mind at all, I hate rapping cold oil and oilpump with a high idle COLD COLD startup anyway. This was previously tuned 10 years ago. Basically want to change the High idle
    Tuning Addict
    6,902
    Airflow - base airflow
    ~Greg Huggins~
    Feb 2024
    29
    would you mind leading me in the right direction?
    Tuning Addict
    6,902
    Quote Originally Posted by RobertT View Post
    Thought I did? It's base airflow and split. Lower the 0 column then blend to the right for the temps you want it to not rev as high.
    ~Greg Huggins~
