Results 1 to 6 of 6
Thread: 04 Z71 LM7 all stock
    Feb 2020
    3
    I installed a innovate lc2 wideband to dial in my Maf and SD airflow , Maf tuned just fine , Sd shows up to -28 error , I have triple checked everything to put it in sd tuning setup , Why Is it so far off from stock ?
    7,952
    No files to look at? Just a story?
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Feb 2020
    3
    Quote Originally Posted by BamatechJon View Post
    sorry it was late and I was tired
    sdwide1.hpl MAFWIDE5.hpl sdwidebandtune.hpt MafWideTune.hpt
    13,609
    In the speed density tune the MAF needs to be set to 0hz for the fail high.
    You also left the short term fuel trims on, that needs to be off. Then reset the fuel trims prior to logging any data.
    Feb 2020
    3
    Thanks I missed it, got frustrated
