As far as I am aware the FSCM in the 2014 ss 1le is the exact same minus some adjustments in the tables considering I have the same pump. I noticed it has an injector flow rate table. The image on the right that goes to 768 KPA is from a zl1 however on the left is mine from my 1le that only goes to 640 KPA. It claims to be an exact copy of the ECM table but my ECM table goes all the way to 768 KPA? I am having fuel pressure drop into the 48 psi range under boost so I am trying to adjust the FSCM to hopefully solve for that, but it just has me confused as both FSCM read 6991 and tables read 12307.
