REDLT4 - I just went threw tuning my MAF and dropping my LTFT's and here is how I did it:
--- I followed this video, below are the steps etc I created to follow this approach:
https://www.youtube.com/watch?v=xO_b8T6d_nI&t=569s
1. Force into Open Loop (Here are the steps I followed)
Fuel Tab
Oxygen Tab
LTFT - Disable
Long Term Fuel Trim
- 283 Scale all away across
Closed Loop Enabled
- ECT vs IAT - Set to 284
** Disable SFST
Fuel Tab
Open Loop / Base
- STFT Open Loop - Disabled
Fuel Tab
Temperature Control
- COT Disable - Note this is turned off already
Fuel Tab
Cutoff DFCO
Deceleration Cut Off
- Enable ECT Set to 280
- Stall Set to 12000
Airflow?
Dynamic Tab
Dynamic Airflow
- High RPM Disable - 200
Dynamic Airflow
Steady State
- Hi/Lo RPM Thresh to 200
- Hi/Lo Map Thresh to 0
Exhaust
General
- Enabled - to disable
2..
Once in open loop, I went to my VCM and added an AFR Err portion to it (attached is the VCM .xml you can use)
3...
I fired it up, did idle, short drives and a couple of spirited drives to capture data (I did this about 10 times - I am a newbie, so better tuners probably only do it once or twice)
Once in the 3% range, (I could only get about 5% ish) place back into close loop and tune the as appropriate.
I believe once you get the LTFT's in like Blindsquirrel is saying, it may help you with the knock? and it may not?
