I have a 2004 Pontiac GTO, 5.7L LS1 V8. I logged some data last night and I have been looking it over. The LTFT values go positive, as high as 4.7, in the following situations:
1) At launch (1st gear).
2) Between the 2-3 shift.
3) When downshifting (approaching a stop light).
4) When punching the throttle, any gear, around 2000 RPM. (Throttle position changes dramatically).
I have not done any tuning to the car, but I have installed a "High Flow Induction" kit (with a conical reusable filter) and NGK TR55 plugs with Taylor 10.4mm wires.
The MAF sensor and conical filter FELL OFF when a friend was driving my car on the Interstate. Since that incident, I feel like I have lost a lot of low end torque. The LTFT's going positive under the listed conditions seems to confirm my perception. Does anyone have any comments? Or would you expect the LTFT's to go positive under those conditions? Thanks.
P.S. The car is a manual 6-speed and yes, I DID reset the PCM after the mentioned incident. I have driven the car at least 1000 miles since then, so I would think it has had time to "re-learn." Thanks again.
