Might be related to modeled tq output I was thinking, but modding VTT and keeping it under 1000ft lbs didnt seem to do anything productive. Dont SEE it closing throttle percentage, but it just shut down mid pull hard hitting a brick wall. I do notice timing jumping way UP when it happens. Is there a cyl/airmass limit at 2.0 gms/cyl I dont recall having issue with one on these ECU unlike some C5 vette stuff. Nothing SAYS its limiting, Tq management Type all 3 say none, Throttle Desired stays 100%
I can literally put one more # on the gate and itll cut it right as it spools up. Run7 doesnt do it, run17 does. ETC Limits in all gears maxed, Max Torque in all gears, Spark Tq and Throttle Torque disabled, in Tip in Limits ETC and Torque Limit2 disabled no change to how it acts with 1 more psi
