Results 1 to 20 of 22
Thread: DTC's w/2.1.12?
    Aug 2005
    Midlothian, VA
    205
    DTC's w/2.1.12?
    I connected after upgrading to 2.1.12 and I see these codes. Can anyone tell me what they are?
    U1000 - Class 2 Communication Malfunction (History) (Immature)
    B3128 - Unknown (History) (Immature)
    U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
    U1064 - Loss of Communications with DIM (History) (Immature)
    I would appreciate any help. TIA
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
    Jan 2006
    Hammonton, NJ
    36
    I noticed the same thing on mine today. I just figured it was because I had the battery unplugged though??
    28,312
    they are BCM codes.
    Oct 2005
    Newport News, VA
    81
    99 Firehawk T/A NBM, M6, 403, TFS, Harrop, etc
    28,312
    he's got a v6, he's not RTTing anything lol .12 can view bcm codes...something it couldnt do with .10
    Oct 2005
    Newport News, VA
    81
    lol Yeah, got a little too quick on the trigger for that one. lol
    Nov 2005
    Fayetteville, NC
    86
    Same thing happened to me, saw these codes.
    B0502 - Unknown (History) (Current) (Immature) - RH DRL Relay Circuit
    B0507 - Unknown (History) (Current) (Immature) - LH DRL Relay Circuit
    B2482 - Unknown (History) (Current) (Immature) - Backup Lamp Relay Circuit
    B2583 - Unknown (History) (Immature) - Left Front Turn Signal Monitor Circuit
    U1064 - Loss of Communications with DIM (History) (Immature) - Lost Communications with BCM
    B2284 - Unknown (History) (Immature) - Battery #2 Circuit
    U1096 - Loss of Communications with IPC (History) (Immature)
    U1255 - Class 2 Communication Malfunction (History) (Immature)
    C2120 - Unknown (SES) (History) (Current) (Immature) - TPM System Malfunction
    '00 Corvette FRC
    HPTuners, AEM WB, PP&C Stg 3 Heads, PRC Gold, G5X3 114, LS6 Intake, Trick Flow 7.4 PRs, SVO 30#, LS2 Chain, 160* Stat, BPP Vortex Rammer, Dynatech Supermaxx L/Ts, B&B Bullets, Magnecor, NGK, B&M 45044, R-D Racing Cross Bar, Z06 Clutch Assembly, DRM Brake Ducts, Goodridge SS Lines, Speedbleeders. . . .Black Z06 Motorsports
    28,312
    like stated they are all BCM codes...they gave us the ability to view them with 2.1.12 im sure if people keep complaining about being able to see them they will do a recall in the next version
    Nov 2005
    Fayetteville, NC
    86
    Quote Originally Posted by foff667
    Not complaining, I actually like it, & hope the next version keeps it.
    '00 Corvette FRC
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Mnay of the U-codes appear after programming. The BCM likes to stay in communications with the PCM & during programming, there is no connection so the U-code sets. Same with IPC, DIM, etc..
    EC
    Always Support Our Troops!
    Jul 2006
    7
    I got the same thing but I couldnt clear them out no matter how hard I tried. Am I missing somehting? I am a complete noob but normally when I get a DTC I just clear them and they are gone. These wont go away no matter how many times or different ways I try. Thanks!
    28,312
    Taken Directly from the help file
    Added - All modules now scanned for DTC's in the DTC window.
    This doesnt mean you can delete, edit, modify the BCM codes.
    Dec 2005
    Orlando, FL
    92
    I think the real issue is the presentation of the codes. They are presented very randomly. How about just a simple sort and maybe a color coding that separates the PCM codes from any other modules.
    Tim
    Jul 2004
    Prince George, BC
    252
    the OBDII standard defines all the codes already
    Uxxx is serial data line errors, each module has its own number
    Pxxx is powertrain
    Bxxx is body
    Cxxx is chassis
    and on and on the list goes
    There is no replacement for displacement?&&sure there is, its called a Blower!
    So, do we ignore these BCM codes? Or, is there room for concern???
    Senior Tuner S2H's Avatar
    Apr 2005
    Schexnayder Racing - Arnaudville LA
    4,387
    if they didnt bother you when you didnt know about them...then its probably nothing to worry about...
    -Scott -
    Quote Originally Posted by soundengineer
    Normally I wouldn't worry about it, but I'm seeing a ton of codes and a few of them make me worry. If you look on the 2nd page of the Document I attached it says C0300 Rear Speed Sensor Malfunction and also for the front too.
    So far nothing seems wrong but....
    How do we know if there is something actually wrong or not.
    Born on 11/20/06 07' GMC Sierra DMax EC 4x4 HPT
    SOLD:2003 Silverado ECSB 4x4, LQ9, Patriot LS6, TR230/224, 31lb inj, TB Stall, HPT & LC-1.
    Apr 2003
    Almost 2000 feet.
    7,876
    If you ran the vehicle on a dyno, you will get ABS codes or if you did a long smoky burnout...
    I also get the U1000 message, but I will get it every time I pull up the DTC window, I only get one though, and it's a lil 'scary' sounding. I've gotten used to it and ignore it now, but I could see how people would be nervous at the "XXXXX Communications Failure" when dealing with a tuning system.
    2005 Stage 2 Saturn Ion Redline
    260whp, 225wtq 14.0 @ 13.7 (2nd time dragging)
    RedlineForums.com Moderator and Eager Tuning Noob.
    Chicago, IL
    Oct 2004
    20
    I'm getting U1000, U1016, U1040, U1096. At first I thought those codes were setting my SES light, but it turns out I had a P0300 lost in the middle of all the other error codes.
    01 WS6 with a little whistle...
    07 TBSS
    98 GTP intercooled & pullied
