What is ETC now called?
2013 OBM A6 CTS-V Coupe
Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
2006 Black Raven STS-V (Traded In)
Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
When is this feature going to be added? Or if it is already in the editor, how is it accessed?File import and export to Emotion and Powerteq devices
- Adds options for tune deployment through third party devices
Issue- When I try to copy from the scanner log it errors out and closes. I was trying to export my LTFT Error%. I had it send the error, not sure if that goes to you guys or not.
An "are you sure you want to close the gauge screen you just spent an hour on without saving" pop-up would be cool
. Lol
Diddo^^^^^
Michael Bray
Rusty Knuckle Garage
Slidell, Louisiana
20yr Master Tech.
Advanced Level Specialist
GM World Class Technician
Shop Owner
ANOTHER NOTE ON DOWNLOADING THE NEW 3.0.
wHEN IT ASKS WHERE TO INSTALL, YOU CAN CHANGE THE FILE LOCATION SO IT WILL NOT OVERWRITE
Michael Bray
Slidell, Louisiana
20yr Master Tech.
Shop Owner
Same issues here.
As you can see everything is configured the same but the ltft graph only populates the top row while the ltft + stft populates the appropriate row.
Anyone else having an issue where the scanner will stop logging on some or all channels? Sometimes it will stop logging the wideband, sometimes it will stop logging everything except the wideband, and sometimes it will stop logging everything. I have replaced the USB cable, and tried it with 2 different widebands and also with the wideband disconnected. I don't know if it is a software issue, because I haven't done any logging in a few months, and updated before I started retuning my car. I could really use a copy of 2.24 so I could try that, I don't have the CD any more.
2012 Camaro SS/RS M6. TVS2300 w/rear OD cog drive and ported lower manifold, On top of a forged 416.
1999 GMC Sierra 2500. Stock 6.0L, LT headers, cat delete, and Airaid intake.
1965 Oldmobile Cutlass. 5.7L LS1/4L60E transplant in progress from 98 TransAm donor car.
In the scanner when you load a log file does it automatically load all data?
I haven't loaded any logs, I am just scanning the car and it stops.
^^I've seen that issue reported multiple times, by multiple people now (where the scanner quites logging)...
can you make it so it DOES NOT auto open the file every time you open the software. its a pain in the ass, it slows it down and for people like my self that are doing different cars every day its a pain..
You don't have to save everything like you did in 2.24.
3.0 maintains your changes between sessions. See: http://www.hptuners.com/help/vcm-sca...hitecture.html
We got this guy Not Sure, ...
You mean, the PREVIOUS gauge layout?
If you hit x to close, you'll keep whatever changes you made.
This is where 3.0 differs than 2.24 though. You CAN save individual layouts from displays (gauge/chart/graph) for future reference, or you can save the entire layout as a whole (using the tool bar buttons at the top).
Those open/save icons in the Layout Editors are only for saving off-line copies of the layouts for sharing/archival purposes.
see here: http://www.hptuners.com/help/vcm-scanner/index.html?gauge.html
The Layout Editor controls the contents of the display. You do not need to save your changes to a file for them to take effect.
