Page 22 of 87 FirstFirst ... 121819202122232425263272 ... LastLast
Results 421 to 440 of 1732
Thread: VCM Suite 3.0 Is Finally Here!!!
  1. #421
    Jul 2013
    8
    Quote Originally Posted by Keith@HPTuners View Post
    The MAF Cylinder Airmass (4 cyl) is a Math parameter, which is virtual. You need to make sure you have all the Channels that Math Parameter requires added to the Channels form.
    I have not looked at your files yet to see what you're missing.
    the parameter is logging correctly in the histogram, it is just the graph that is not populating correctly. That is what leads me to believe there is a bug somewhere.
  2. #422
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    477
    What is ETC now called?
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  3. #423
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by PGA2B View Post
    Throttle Position I think.
    We got this guy Not Sure, ...
  4. #424
    Dec 2015
    Idaho
    13
    When is this feature going to be added? Or if it is already in the editor, how is it accessed?
    File import and export to Emotion and Powerteq devices
    - Adds options for tune deployment through third party devices
  5. #425
    Nov 2004
    St. Louis, MO
    477
    Issue- When I try to copy from the scanner log it errors out and closes. I was trying to export my LTFT Error%. I had it send the error, not sure if that goes to you guys or not.
  6. #426
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    An "are you sure you want to close the gauge screen you just spent an hour on without saving" pop-up would be cool
    . Lol
  7. #427
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,023
    Diddo^^^^^
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  8. #428
    Dec 2013
    Slidell, La.
    1,023
    ANOTHER NOTE ON DOWNLOADING THE NEW 3.0.
    wHEN IT ASKS WHERE TO INSTALL, YOU CAN CHANGE THE FILE LOCATION SO IT WILL NOT OVERWRITE
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
  9. #429
    Tuner in Training Srtboost4u's Avatar
    Aug 2012
    34
    Quote Originally Posted by rage03usa View Post
    I am running into an issue with creating a KR graph. Everything looks to be setup correct but it is only updating the top row of data even though the active cell will highlight other rows. The parameters all work and are updating correctly in other parts of the vcm scanner. See attached image.
    Same issues here.
    As you can see everything is configured the same but the ltft graph only populates the top row while the ltft + stft populates the appropriate row.
  10. #430
    Anyone else having an issue where the scanner will stop logging on some or all channels? Sometimes it will stop logging the wideband, sometimes it will stop logging everything except the wideband, and sometimes it will stop logging everything. I have replaced the USB cable, and tried it with 2 different widebands and also with the wideband disconnected. I don't know if it is a software issue, because I haven't done any logging in a few months, and updated before I started retuning my car. I could really use a copy of 2.24 so I could try that, I don't have the CD any more.
    2012 Camaro SS/RS M6. TVS2300 w/rear OD cog drive and ported lower manifold, On top of a forged 416.
    1999 GMC Sierra 2500. Stock 6.0L, LT headers, cat delete, and Airaid intake.
    1965 Oldmobile Cutlass. 5.7L LS1/4L60E transplant in progress from 98 TransAm donor car.
  11. #431
    Nov 2004
    St. Louis, MO
    477
    In the scanner when you load a log file does it automatically load all data?
  12. #432
    I haven't loaded any logs, I am just scanning the car and it stops.
  13. #433
    Dec 2014
    592
    ^^I've seen that issue reported multiple times, by multiple people now (where the scanner quites logging)...
  14. #434
    Dec 2005
    Sydney Australia
    510
    can you make it so it DOES NOT auto open the file every time you open the software. its a pain in the ass, it slows it down and for people like my self that are doing different cars every day its a pain..
  15. #435
    Quote Originally Posted by jtrosky View Post
    I wish I had saved 2.24 before I loaded it, or if they would post an attachment where we can get it in case we need it.
  16. #436
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by 383_Stroker View Post
    . Lol
    You don't have to save everything like you did in 2.24.
    3.0 maintains your changes between sessions. See: http://www.hptuners.com/help/vcm-sca...hitecture.html
  17. #437
    Sep 2002
    Chicago, IL
    6,397
    Yes, you no longer need to "load all data" in the graphs
  18. #438
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by VYSSLS1 View Post
    You can disable that in the Tools->Options menu
  19. #439
    Apr 2009
    258
    So, say I build a gauge screen, accidentally hit the x to close. How do I get it back?
  20. #440
    Sep 2002
    Chicago, IL
    6,397
    You mean, the PREVIOUS gauge layout?
    If you hit x to close, you'll keep whatever changes you made.
    This is where 3.0 differs than 2.24 though. You CAN save individual layouts from displays (gauge/chart/graph) for future reference, or you can save the entire layout as a whole (using the tool bar buttons at the top).
    Those open/save icons in the Layout Editors are only for saving off-line copies of the layouts for sharing/archival purposes.
    see here: http://www.hptuners.com/help/vcm-scanner/index.html?gauge.html
    The Layout Editor controls the contents of the display. You do not need to save your changes to a file for them to take effect.
