can this software correct the parameters that causes the stock pcm to read false knock and misfires on some of the larger cams?
also, as far as TDC ? codes, how can you tell that they have been deleted? Will you get an error if you scan the computer for codes and those parameters have been deletd, or will it simply not show anything if they have been deleted from the pcm?
