Page 6 of 64 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 1261
Thread: VCM Scanner 2.25 Beta Now Available
  1. #101
    Sep 2002
    Chicago, IL
    6,397
    No, but there is a new build every day.
    We got this guy Not Sure, ...
  2. #102
    Sep 2002
    Chicago, IL
    6,397
    Tomorrows scanner will have functional Table Graph for log files (not scanning). It's a bit quirky, but at least you can graph data now.
    It also includes the ability to open MoTeC .csv files (with timestamps). We'll be adding more .csv format opening capabilities in the future.
  3. #103
    Feb 2014
    Sydney
    295
    Keith, I have requested a 2.5 Beta copy from support the day of the release and again a couple of days later, still nothing on my log in page, when do you anticipate outstanding beta copy requests being completed?
    Tune with actual data not simulated data!.....Applied Road/track Tuning
  4. #104
    HPT Employee Engineer@HPT's Avatar
    fecadefa
    615
    Quote Originally Posted by Yortt View Post
    Someone should get back to you later this week. We apologize for the delay.
  5. #105
    Feb 2014
    Sydney
    295
    Thanks for the prompt response.
  6. #106
    Sep 2002
    Chicago, IL
    6,397
    Tomorrows beta scanner will also have the ability to open/save layouts from the Layout menu.
    Individual display form layout open/save from the layout properties forms are still pending.
  7. #107
    Feb 2014
    Sydney
    295
    Well, l managed to get my hands on a copy of 2.25.1846 Beta, loaded it into my lap top connected to the car. Tested the new scanner out appeared to work fine with limited pids basically useless on Australian fords for tuning in its current format when it finally works it will be a huge leap forward for Australian fords.
    Went back to the now 2.24 stable version obviously modified to operate with the new firmware... well well! ....now it is unable to connect to the VCM...went back to the 2.5 scanner and connects fine, given we don't have access to support and given when we do they will be inundated can anyone off any suggestions?
  8. #108
    Aug 2012
    Melbourne Australia
    344
    Yortt, you will need to update to a later version of 2.24 (2.24.1080+) for this to work. See:
    http://www.hptuners.com/forum/showth...NOUNCEMENT*-**
  9. #109
    Feb 2014
    Sydney
    295
    DarrylC, thanks for the advice I thought I had the latest version of 2.24 loaded on my lap top just checked and I do not, I guess I owe HP Tuners an appology on this one.
  10. #110
    Nov 2007
    232
    2.25 and setting up for external wb logging? Am I missing something for setting this up or is it not available yet?
    "I didn't fail, I just found 100 ways to do it wrong." - Benjamin Franklin
  11. #111
    Aug 2012
    Melbourne Australia
    344
    Not available yet on Fords don't know about GM.
  12. #112
    Nov 2007
    232
    Well funny you should mention ford and gm...I'm looking to set it up to log a innovate dlg-1 on a 2013 Challenger SRT. It's like the external input isn't configurable yet. That's how it seems. There's no drop down or anything. Just wondering if there's an eta on this function. Kinda one of those critical things when the vehicle you're trying to tune doesn't have a factory wb.
  13. #113
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by schaid View Post
    Just do your Dodge fuel tuning with 2.24. There is enough logable parameters to do it. You just need to make a custom PID for Pressure Ratio and set up your histogram axis'.
    Jaime
  14. #114
    Apr 2013
    Buffalo NY
    93
    Its been 2 weeks... =) Need some Ford Support like a fat kid needs cake.
    2019 Ford Raptor Tow Rig Scarab 195 Open 250HO
    2008 Shelby GT500 VMP Gen II-R (17psi), JLT 123mm CAI, Ford SCJ Monoblade Throttle Body, 56# Injectors, BoostAPumps, VMP triple pass heat exchanger (dual fan), 170* thermostat, BBK long tube headers, Dual resonators, Magnaflow Catback, LC2 Wideband, RXT clutch
  15. #115
    Aug 2010
    49
    Can someone send me a link to download 2.25
  16. #116
    Mar 2015
    unsure If anyone has already asked this but any idea when or if abs codes and sensor readings will be offered? gm is my main interest.
  17. #117
    Sep 2002
    Chicago, IL
    6,397
    Quote Originally Posted by Mongorat427 View Post
    Please e-mail support for beta access.
  18. #118
    Feb 2015
    Indianapolis
    36
    Just tried 2.25 Beta, and it did fix the O2 sensor bug issue I was seeing on 2.24. That is, I can close the scan file and reopen it and the both B1 & B2 O2 sensor data are still good.
    However, I have some questions about the Beta version:
    1) I picked "Vehicle default" from the Channel Configs drop down menu because shows it will datalog Total Knock Retard, but when I hit the scan button the table switches to SAE defaults by itself (i.e. - no Total Knock Retard)?
    2) The SAE table begins to populate with data after I click on scan, but the gauges and chart displays don't show any activity, but when I play back the log file, they both show data like they should?
    3) I tried making a histogram using data that was scanned on the table, all I could see when playing back the histogram was the cell would "light up" as the X-Y data points make it jump from cell to cell OK, but there was no numerical data being populated in the cells ?
    Thanks,
    Joe Peek
    2005 Mustang GT/5 speed
  19. #119
    Aug 2012
    Melbourne Australia
    344
    Thanks joepeek, this explains a lot. When I open an old log file the Plot vs Time is populated with data but not when you are live scanning.
  20. #120
    I have the 2.25 beta software and I'm still gettiing error codes trying to divide by zero?
