Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 111
Thread: E38/67 Custom OS Addition?
  1. #61
    Quote Originally Posted by LSxpwrdZ View Post
    Now is it possible to keep adding support to OS's in the E67 and E40 variants?
    The current plan is E38 (about halfway thru), E67, E78 (complete), E39 (complete). I can do E40 as well if people want it.
    I count sheep in hex...
  2. #62
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Quote Originally Posted by SRT10KLLR View Post
    Yeh, I installed that on a 2010 Camaro back in 2010 but never used it. I have both softwares but use HPT for the Camaro and the other one for the 2003 Silvy because of the COS for Nitrous. Also use it on a NNBS 2007 Silvy with a Maggie and Nitrous.
    I asked support@HPT a couple months ago "On there site it said that they can't read your COS because it's locked but that theirs is not locked just that HPT does not recognize their OS.
    How about using HPT to run the E85 tables like them could that be done? There is a wire that I hooked up almost 3 years ago into the ECM that when grounded(or install an actual E85 sensor) you run off the E85 tables or combination thereof."
    And was told "We have no plans to add additional features to our custom operating systems."
    Glad I don't have to switch it now that I removed the nitrous and installed twins on the Camaro. DSteck, I switched to the 2.5Bar COS and used the ZR-1 MAP sensor per your recommendation. I want to use the E-85 tables to adjust timing and fuel when the methanol spray. Can that be done?
    Yes, you can. I'm not sure how well the fuel will work unless you have an alcohol PE table.
    Chris, I wouldn't bother with E40/E67 until somebody finds the pin. Lol.
  3. #63
    28,312
    I would assume its much easier to try to add them now while everything is fresh, I think its only a few constants & switches which if the locations are similar are usually pretty easy to add since he's already mapped them on a bunch of the master files. If it overkill now its simply future proofing
  4. #64
    Mar 2008
    St. Louis, MO
    4,862
    Fair enough. Lol.
  5. #65
    Mar 2008
    Sothern California
    32
    For the fuel side I was thinking of adjusting the stoich since methanol's is different and pulling some fuel since some is coming from the methanol.
    Do I have to have the latest version 2.24 for this as I am still on the beta? Also, I was using the normal tuning but recently had a shop make me a safe 10psi tune but switched to the 2.5 bar COS. I did not know I had to buy more credits since upgrading to a COS on the other software did not require that. Currently I can't make any adjustments to the tune. Anyways, how many more credits do I need to buy?
    2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
    2004 Dodge Ram SRT-10 - Silver
    2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting turbo
  6. #66
    28,312
    The tables are in the stock code, no custom operating system is required. The only thing that is requires is the newest public software version 2.24.61 or newer.
  7. #67
    Mar 2008
    Sothern California
    32
    OK. So I have to upgrade from the Beta then. The switch to the COS was based on Dave's recommendation as it is the correct way to do things and you get better fan controls etc.
    BTW, ever since the turbos went in the tranny shifts a whole lot softer but the tranny side was not touched by the tuner. What could be causing it? Is the incorrect tq being used?
    Just got 2 more credits so I should be able to make changes now.
  8. #68
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by Chris@HPTuners View Post
    Thanks Chris! This is a huge help as these tables can be utilized on nearly every power adder vehicle! Thanks a bunch for the awesome support!
    Located in Central Kentucky
    ShorTuning
  9. #69
    E38 are completed, will be in 2.24.064 tomorrow.
  10. #70
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    Thanks Dave and Chris , new open possibilities now .
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
  11. #71
    Mar 2008
    St. Louis, MO
    4,862
    I got actual flex fuel working. The pigtail that was on the original sensor I bought had the wiring colors wrong, and instead of wiring it according to pin location like I should have, I took the lazy way and assumed that purple, pink, and white were proper. A quick pin swap fixed it. Either way, I'm running a brand new GM sensor now too.
    Looks like pump gas is about 8% ethanol.
    http://www.dsxtuning.com
    Just say no to bull s***.
  12. #72
    Dec 2008
    on the Dyno
    1,825
    Can I get this functionality added to a CTS-V OS. Here is the file pulled from the car. Thanks Guys
    ShorTuning
  13. #73
    Mar 2008
    St. Louis, MO
    4,862
    Did you find the right pin?
  14. #74
    How is this working out for you?
  15. #75
    Mar 2008
    St. Louis, MO
    4,862
    Haven't driven the car because I am waiting for a new brake caliper since mine is stripped out.
  16. #76
    I am also looking for the pin, and having a problem finding wiring for the e67 ecu with flex fuel sensor to wire a actual sensor in for e85 use.
  17. #77
    Mar 2008
    St. Louis, MO
    4,862
    If somebody lets me borrow a E67, I'll find it manually.
  18. #78
    Jan 2007
    LOS ANGELES
    81
    what car came with a e67 and flex fuel ? escalade ?
  19. #79
    Quote Originally Posted by HyeSpeeder View Post
    I don't think there was one. That is the problem
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
  20. #80
    Any luck with that yet? $50 cover the cost for you to go test drive a e67 ecu and find it for me? take Paypal? lol
