Sorry to Hijack, but I am in the same boat with a 97 with a 454. Has anyone put a 98 black box into a 97?
I haven't, but the pinout is close, very close.
I can post the pinouts tomorrow for the 98 computers. Dont know what the 97's are, though.
Old rusty 88 Camaro
350 w/ Edelbrock victor EFI intake + 1000 CFM TB
'279 PCM with a custom tune and code patches by me
TKO 500, 1LE performance package, etc...
I'll see what I can find.
I know O2 sensors are moved, probably injectors down a bit too. But most else is very close.
For some info on the 98/99 PCMs, check out this page on diy-efi.org. In the bottom, they have schematics for the PCMs with the pinouts listed in each schematic. Somewhere I have complete pinouts for each connector. Ill see if I can dig them up. http://www.diy-efi.org/gmecm/ecm_info/16250279/
Old rusty 88 Camaro
The 96 C/K list 5.0L, 5.7L, & 7.4L
I didn't check to see if the pinout for the 7.4L is the same on the other years
Attachment 18865
Attachment 18866
Attachment 18867
Attachment 18868
Attachment 18869
I am looking at doing this swap, does anyone know wher i can get the base calibration file for a 2001-2002 GMC Savana or CHev Express.
Ward
I know nothing about these
Attachment 21787
Attachment 21788
Attachment 21789
Thanks for the cal files, I appreciate it, and thanks for the warning, I am sure they will be closer then what I am going to get with the job that is going to show up today.Another shop is putting a rock crawler together and I am going to tune it, he has it running after the ECM swap, but he said it cherries red's the header as soon as it starts. Other then that I don't know anything about it. So, I am sure that this will be a step in the Right direction.
Has anyone thought about using one of these 411 PCM's or even the 98-99 Vortec PCM's on an LT1? Seems like it'd be alot easier to put a distributor in a LT1 than it would be to buy a huge 24x LS1 coil pack conversion. Just a thought that I may try to tackle with a buddies Impala. We really want HPTuner support for his car but don't want to go through all the 24x conversion to use coil packs and this seems like a little easier to do than the other anyway.
Whats your alls thoughts on that?
Does anyone have the pinouts for the 411 PCM Express Van?
James Short - [email protected]
Located in Central Kentucky
ShorTuning
Will HPtuners even scan and/reset codes on the early "black" ecus ?
ecuboss
HSV Clubsport R8 - LS3 - A6
So Ive got one of the old "black" ecm's with a service number of 16244210.
My scanner is 2.23.3616.25998 beta and it will connect and read the basic sensors such as throttle, coolant and map. Editor doesn't work unsuprisingly.
This is a complete loom that i have picked apart and intend to try starting the engine - will report results.
ecuboss
So I have been cross referencing the differences in the 97 and 98 computers. I am looking at going to the 98 computer for my 97 Vortec 454. I have found 13 differences in the pin outs that do not have a cross reference in either year. Do any of you guys have any idea about these? I have them in the spreadsheet here.
Just an update. I ended up going with a 0411 swap. Everything has turned out good. I would recommend the 0411 for anyone with an OBD 2 OBS truck.
1997 Chevrolet K2500 ECSB L29/4L80, Mid-length Headers, Cat-delete, Custom Catback, Airlift Airbags, 0411 PCM Swap.
2004 Pontiac GTO M6 Ported Dart 225s, SI5 cam, Ported FAST 90, SLP LTs, Bassani catback, Pedders Track Coilover, GMM Ripshift, Spec 3. Numbers to come...
Bump. Plugged into the van. Scanner seems to be working great. Obviously no editor support. Any updates or as of now is an ecu swap the only way ?
About to swap the 350 vortec in my van for the 454, will need to do something. Probably the 99 454 ecu
