This Doco came from the LS2 basic tuning guide that can be found in the stickys'. I've modified some of the content, and tuned my Ls2 GTO with it. it's still very basic, but i tried to add a little bit more content to it, i'm sure i'll add more as needed. suggestions are welcome. You can tune anything newest than E40 with it, MAF wise, VE have to be done with the Ve calc which can be found here: http://www.hptuners.com/forum/showthread.php?t=26884
Download LS2 Tuning Guide 01262010.hpt, The file is 2mb and change. to post it, i've renamed the extension from .doc ( MS Word 2003-2007 format) to .hpt
Download the file, rename the extension to .doc and that's it.
You'll need MS Word to open up the file, if you don't have MS Word installed in your PC/Laptop, you can download and install the MS Word viewer. this one is free, but it won't allow you to make changes, just to view,print and copy word documents: http://www.microsoft.com/downloads/d...displaylang=en
I've also uploaded some config files as well.
Enjoy.
Noted, added a little change in the guide at 4:30PM EST 01/26/2010, so download it again if you already did.
