Wiring to Hook up Wideband to Scan AFR
Got everthing ready but what wires go were? I am using a stereo 3 way plug for LM-1 so what wires go to adaptor out of HP Tuners plug. I have a red wire and black and shield wire. Set LM-1 up for output #1 & 0 to 5 volts.
Re: Wiring to Hook up Wideband to Scan AFR
configure outputs 1 and 2 to:
0V = 10 AFR
5V = 20 AFR
that way it doesn't matter which wire you pick (red or black) it will be configured correctly.
shield wire goes to the black (ground) on the pigtail
red or black output goes to pin 1,2,3 or 4 on the pigtail, your choice
make sure that if you splice to pin 2, then you insert wideband logging to the correct cell in the log table. There are diagrams in the help files!
2002 Quicksilver Corvette Z06
And then...
