I got home from school today. Came in thought I would move the rev limter up to 6700 and I disable some air injection codes. While I got done with that and went out to my car and flash the new bin I made. It took a long time compared to normal times to transfer. It finally got done . I go to crank the car and it wouldn't crank it just turned over. So I went back to load the stock bin. When I tryed to load it it came up as Request Download Failed-Unknown Error. I tryed it serveral times and it said same thing.
You can't hear fuel pump kick on. I went to VCM Scanner and the inj B1 and B2 to are up to 25. I dont if theyr'e supposed to be like that or what. It is also set a code off DTC P0601 Control Module Read Only Memory (ROM).
I need help I need my car back on the road.
My car is
1998 Z28 M6
Thanks,
Greg
