Let's say you go make a dyno pull to get HP/TQ numbers.
You whip out the tuner and remove all the TM limitations.
Now you make the dyno run again to check for increases.
Will you see any measurable change? Does it stay the same?
When does TM come into affect? When you go wide open and
between shifts? Any other times? If you're cruising along down
the highway at 2000 rpm, is TM pulling any timing?
I'm basically just curious to know if removing TM actually
gives you more power (that you'd see on a dyno) or if you
just "feel" those same dyno numbers more because you are
not getting hamstrung while trying to apply the power?
Does my question make sense?
