Originally Posted by
EC_Tune
Since you will be using the same PCM as the LS2's you will end up tuning the same.
Start by turning off the LTFT and tuning the MAF tables based on the STFT. You can set up a filter to keep PE values out of your STFT data.
Get the fuel right and then work on the spark. If you have excessive KR fix that immediately so you don't damage anything. Once you have the fueling correct you can then attack the spark advance. Remember to re-check fueling because spark can have an effect on fueling.
Enjoy!
