Results 1 to 3 of 3
Thread: P0340 and P0341 codes are set LS2
    I installed a new cam with 16 degrees of overalp along with a Comp Cams adjustable timing set for the LS2. Now I'm getting cam position sensor codes being set.
    I checked the wiring, everything is fine, checked the sensor and made sure it's tight and secure. Still getting the codes, all the time.
    Could it be a problem with the Comp Cams timing gear?
    Any help would be appreciated.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    could it be a problem with the sensor itself?
    Sulski Performance Tuning
    Apr 2003
    Almost 2000 feet.
    7,876
    Contact Comp. They can probably steer you in the right direction.
    Always Support Our Troops!
