I've got a 99 Vette that I'm having throttle transtion or tip in KR with. When I look at the raw excel file, it seems that one 02 is always low(double digit) at that onset of the throttle opening. So I have a couple questions.
Would this be a lean hole in the VE table and would I tweak the primary or
secondary?
99 Vettes appear to have the burst knock table set to a delta of 16 and
then other burst knock table is zeroed out,is this normal?
I pulled a bin from Horist's site and the 99 Vette there is the same as
mine but 99 F-body's have the burst knock info populated as do later model
Vettes.
Any thoughts would be appreciated. Thanx, Jeff
