Results 1 to 4 of 4
Thread: Why is this 6L not locking up cruising
    Baltimore, Md
    1,208
    Missing something but it never seems to want to lock up, I can command it to manually no problem
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    cammed? need to modify misfire tables or else lockup wont engage
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Also check the brake switch input. Sometimes they are backwards, if you lightly touch the brake pedal while in cruise range, and it locks up, then the brake switch is working backwards the what the ECM is looking for, Common on older conversions.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Baltimore, Md
    1,208
    Quote Originally Posted by luisdavid11 View Post
    Dammit, i turned them all back on to diagnose a misfire from a shit coil pack relocation harness and forgot to turn back on!
