Results 1 to 20 of 20
Thread: Historams reading just the first cell when scanning
    Hello, its been awhile since I've scanned a vehicle with hptuners, but I'm only getting the first cell in the histograms even in advance , retard , or O2's and the others. I'm I missing something , I know its been awhile and I had a stroke years ago but can't figure it out, thanks for any help. Steve
    1996 Camaro 3.8 M5 to A4 conversion, VS cam, 3" exhaust, 9:5.1 forged pistons, Clev.77 bearings, Comp 130lb springs/.105 pushrods, Manely modded retainers, Walbro 255, PLX wideband,65lb injectors, Every Suspesion mod. alot of other mods- GT35R Turbo.http://www.cardomain.com/ride/2441235
    2008 Silverado LTZ 6.0 L76 Dynomax exhaust K&N intake
    Tuner blkscooby's Avatar
    Aug 2010
    Mesa, AZ
    81
    I'm having the same issue with my spark advance and retard graphs. Here is my config and graphs.2009 G8 GT.Channels.xmlSpark Advance.Table.xmlRetard.Table.xml
    09 G8 GT- 224/234 114 cam, 3200 stall, 3.45 gears, Vararam, 1 7/8" headers, 3" exhaust, HSW nitrous
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    This typically just means you aren't scanning the necessary pids in the channels display. Without a screenshot of what you are seeing along with the scanner log it is impossible to assist you any further than that though.
    Aug 2010
    Mesa, AZ
    81
    Thanks Bill. Here is a screen capture from my log and config and the log attached. I realize that it usually is an issue with not logging the correct PID but I tried several different ones with no success.
    2018712 v88 log 1.hpl
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by blkscooby View Post
    works fine for me once you create a valid histogram such as the one shown
    How do you create a valid histogram? Is there a how to section to do this?
    HP Tuners Support
    (foff667)
    28,268
    Please see the screenshot I attached as a starter guide, there is a TON of additional information & how to's for using our scanner in the scanner section stickies https://forum.hptuners.com/showthrea...tarted-Threads
    Aug 2010
    Mesa, AZ
    81
    Thanks Bill, the charts work now referencing Manifold Pressure as the rows. I was trying to use Spark Airmass to align with the spark advance tables in my E38 PCM. Not sure how I translate from log to tune when the axes arent the same.
    I think I found my problem, been dealing with a shorted out map sensor on the Camaro and I think its causing the graph just to read one cell, scanned my truck and its fine scanning, just the Camaro is where it has the problem on the scanner it just stays at 10 and doesn't move in the chart scanning it. And I get the dtc107 and dtc1107 which are both Map sensor codes I'll rewire it tomorrow and see if it fixes the problem.
    Ran a wire from the pcm to map where it was shorted. Got my map sensor readings back, but instead of one cell in histogram its the first row now, ill have to post my log because im lost now. Will post it tomorrow when i have my laptop again.
    13,565
    Likely still missing a parameter in the main channels list.
    I always make sure I'm logging cylinder airmass when doing timing stuff on older vehicles.
    Thanks, ill try it both ways, just using the default settings. Works on my 2008 chevy truck. My camaro is a 1996 using a 1997 pcm. Never had trouble before so Im pretty much stumped.
    Figured it out, scan down below, let me know if you need anything else.
    Heres a scan.
    Heres something interesting, tried another laptop with version 2.2 and it logs the Histograms except for spark retard, so I pretty sure its the programing.
    13,565
    You are not logging engine rpm.
    It says engine speed rpm on the top, and it works fine on my truck without changing anything. What goes on the top then? I get more confused with it everyday.
    13,565
    You are missing the point here.
    Whatever you want to log MUST be displayed in the main channels list. So if you want your RPM to be logged, you must select engine RPM in the main channels list. Currently it is missing and thus no data will ever show.
    Even reference those pictures above. On the left in the channels list, that person was logging engine RPM at the very top. Your last log has very few parameters in there and engine RPM is not one of them.
    Ok thanks ill give it a try.
    That fixed it , thanks again.
