Results 1 to 14 of 14
Thread: Flex Fuel Timing...2015 L83
    '15 Sierra, didn't come with Flex Option.
    Installed Sensor and Enabled.
    I'm currently using stock timing tables across the board but would like to optimize for 93 as well as flex.
    Two questions:
    Why all the peaks and valleys in the stock Alcohol Multipliers?
    What is a safe upper range when running over 70% ethanol - 28* Total?
    Screen shot of log vs. tune.
    '18 Sierra L5P
    '03 Sierra 4.8/NV 3500: LS6 Cam, HPT Tuned
    '15 Explorer Sport - SCT, AEM (Wife says...it feels faster??)
    '01 Z06
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Dips are probably torque management during shifts or decel or something like that. You aren't logging pretty much anything regarding timing so hard to tell what's pulling it
    Sorry I was referring to the stock timing tables in the tune at WOT.
    '18 Sierra L5P
    '01 Z06
    May 2016
    15
    I converted mine to e85 a little while ago hereis something that will help change the fuel type faster
    Also I've attached a Stock Truck 5.3 E85 for comparison
    Stock FlexE85.hpt
    Dec 2015
    Miami,Fl.
    290
    How much ethanol percentage is your sensor picking up?
    2023 Ford Maverick 2.0T AWD
    May 2016
    15
    I highest I've seen has been 83%
    Dec 2015
    Miami,Fl.
    290
    Quote Originally Posted by tpawlish View Post
    Lucky you. Mine won't go higher than 75%.
    When I manually check my local gas stations e85 with a holley test tube it checks out to 85% ethanol. Normally I wouldn't care, but with these new Gen V's if it doesn't see at least 80% it won't reference the flex fuel tables 100%.
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by HeavyChevy305 View Post
    That's not entirely true, you can setup the ethanol tables to read what ever you want... my setup has all timing in at E65
    May 2016
    15
    Quote Originally Posted by Ben Charles View Post
    he's right on my Race tune anything above E50 gets all the timing
    Dec 2015
    Miami,Fl.
    290
    What tables do you specifically alter? I haven't messed with any of the flex fuel tables because i'm afraid it will mess with the factory algorithms. From what I understand, most of the tables reference each other, so messing with one will create a domino effect.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Specifically to do what?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Dec 2015
    Miami,Fl.
    290
    To take 100% advantage of the Flex Fuel Spark and Max Torque Timing modifier tables. They don't default to the multiple cell of 1.00 till the sensor sees 80%. I also noticed that the Injection Timing SOI base tables also multiply as alcohol content increases. From my understanding, SOI base and spark timing go hand in hand with these DI motors.
    Aug 2009
    Calibrating
    3,373
    Right click and edit axis...
    Probably half the axis in my calibration are modified
    Dec 2015
    Miami,Fl.
    290
    Damn! You learn something new every day lol.
    Thanks Ben.
    These 2017 5.3's come with some conservative Flex Fuel Spark tables. Pushing 20/22* max at WOT while logging. My Flex Fuel spark modifier table is different than the O.P.'s
