Results 1 to 5 of 5
Thread: Granatelli mass airflow sensor
    Apr 2005
    1
    Is the Granatelli mass airflow sensor compatible with HPTuners software?
    I know that it can be programed itself, with their "handheld"
    so my question is, will it cause a conflict of any kind?
    Nov 2002
    Central Florida
    2,503
    Re: Granatelli mass airflow sensor
    There's not a conflict, the GMAF is just not properly
    calibrated when you use a stock table, they provide
    no realistic cal info of their own, and I have yet to see
    anyone who's dialed it in. But you could. I would
    recommend starting with a screened stock unit and
    determine your car's MAF:MAP*RPM curve and use
    that to arrive at the proper GMAF table.
    The GMAF handheld I've seen does not program the
    MAF, it's a rebranded Predator (presumably with some
    tweakage but perhaps not) for the bent MAF cal.
    Granatelli does offer a MAF you can program but it's
    big bucks and I haven't seen anyone who says they
    use it.
    The benefits the GMAF gives you, by faking lower-than-
    real airflow input, you can get for yourself on the up-and-up
    (set your own spark advance and power enrichment, and
    have the benefits of realistic calibration as well (sensible
    fuel trims, an automatic that doesn't slip, and like that).
    May 2003
    AL
    22
    I've got a granatelli and havent done any tweaking on my maf table. I did just a bit on my VE table but my fuel trims are near perfect. Maybe I just got lucky though. It would be interesting to find out if the table needs to be different than stock.
    Jan 2005
    maine
    32
    you may have adjusted a 'correct' VE table to compensate for an 'incorrect' MAF signal!?
    I could never keep my fuel trims consistant when I adjusted the VE table. As soon as I worked on the MAF table the fuel trims fell in line and stayed that way.
    May 2003
    AL
    22
    I have a GMAF and my fuel trims were always between 0 and -2 at cruising before the cam. Never touched the VE or MAF tables. After cam the trims are way negative, but nothing a little VE moddin' won't take care of.
