I just recently swapped a heads/cam 6.0l in my 01 RCSB 4x4 Silverado.
I have been tuning with HPTuners. I got my idle right now and am currently part throttle via SD tuning. Now I copied over all the tables from an 02 6.0l except transmission stuff. I have got all my numbers pretty much 0 maybe a little negative. No knock and WOT runs are around 900mv. I followed all the directions of the programming for dummies.
My truck is still a dog compared to what I thought it would be.. Where can I find some more power. Is my spark and fueling tables too low? Any help would be much appreciated. I can send my VCM file and any other info if someone wanted to look at it.
Here are the specs on what has been done to the truck
04 6.0l bottom end, taken all apart with new bearings and gaskets
TR220 112 lsa cam
Ported 6.0l heads
new oil pump
4.8l intake and injectors
Yank 3000 stall
Transgo HD-2 shift kit in my 4l60e
B&M Trans cooler
Thanks again for any help....
