The RAF tuning for the LS2 looks to be very similar to the LS1/6 but I'm confused about something. One cell is 0.00'd out while the others show a normal value. The cell that is 0'd is the one @ idle RPM. Whats the trick to changing the values?
Phil
1999 Corvette Coupe
Worlds Fastest 346" N/A Coupe
ProStreet Motorsports
HP Tuner SD specialist All GM Vehicles
2000 Mustang 438" LSx 4.70 @ 164
NEW 346" N/A testing: 10.4 @ 132.4 N/A(875')
NHRA Corrected: 10.21 @ 134 N/A
Old Nitrous Best: 10.0 @ 138.89(181 DA)
these values are the minmum allowed idle airflow, they are not the RAF like the LS1.
The idle airflow will not learn down below these values so you can put a lower bumpstop on idle if you want. The idle cells in PN are set to 0 in most GM cals so the idle can learn down to whatever it takes to meet the desired idle RPM.
Chris...
I count sheep in hex...
