LSRacing
Jamy, Chris sent me a new beta, within minutes of me
asking for a 'fix' , so I can see your file now.
That compare function is so cool & easy to use.
I see you too put hi-octane in place of low-octane.
And I see you added more in 1600-2400rpm range.
I will try that.
Did you change some of the variable camshaft stuff, or is
that just the diff between your 2003 & my 2004 ??
Don't know if I would touch that stuff as I don't know
where to find info on that, to change it ??
I see you haven't changed any DFCO either, I really don't think
that we have ALL the DFCO tables that we need to make it work great for us, as my Z28 program has probaby a lot more parameters for DFCO.
There's maybe 2-4 MPG more if we can get DFCO set-up right.
Have you changed some of the trans force/pressure tables too, or is that
too the diff between your 2003 & my 2004 once again ??
O2 switch point ? Hmm, maybe it will be here with the next release.
Dave
