Results 1 to 6 of 6
Thread: 5.3L with big cam won't idle at target speed
    I have a 2014 5.3L with a large cam and I am having a hard time getting it to idle at my target idle speed, and timing is jumping all over the place. It also will just shut off randomly at above 2600 when I let off the pedal. Any help is appreciated.
    Tuner 69camaro5speedefi's Avatar
    Dec 2005
    INDIANA
    57
    409Jake 409Jake is offline
    Nov 2011
    21
    Im dealing with similar issues on a similar combo, and found that lowering the Airmass A-D tables in the idle area is helping bring the idle up to commanded. I swagged out 80% first, then been fine tuning from there.
    I dialed in the SD and Maf first and trims are in line... Still needs some work, but getting closer it seems...
    helped me
    Thanks for the reply. I greatly appreciate it
    Dec 2005
    INDIANA
    57
    your welcome
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    make sure airflow is correct. What are you grams/cylinder and what hertz is it idling at?
    Airflow=torque and the ECM is trying to hit a torque number. It will do what it needs to do so even if the engine idles with negative timing values and messes with the throttle blade.
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Mar 2014
    McAllen,TX
    160
    make sure your fueling is correct it will help you get your targeted idle speed
    Josh Performance Tuning (956)784-0059
    https://www.facebook.com/joshperformancetuning
