Results 1 to 5 of 5
Thread: Can a E67 ECM go in place of the E38 ECM?
    Aug 2005
    335
    Can a E67 ECM go in place of the E38 ECM? I am wondering because I would like to take advantage of the E67 to control the FPCM. The E38 has the tables but makes no difference if I make any changes.
    There is a shop called ADM that modifies the FPCM so it can be adjusted by the E38-not sure how or what they do? Anyone have an idea?
    GO RAIDERS!!!!!!!!!!
    02 C5 Z06
    8.8@160
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    2010+ Camaros and some trucks have E38s with FPCMs.
    Wire it all up correctly, and there's no reason you can't use an E67.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2008
    1,668
    What year E38 are you trying to mess with the FPCM on? It probably needs a newer OS (which may require newer hardware).
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    Aug 2005
    335
    2015
    02 C5 Z06
    8.8@160
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Ran an ADM FPCM on the stock fp for a while, needed more pump. It couldn't handle the ZL1 pump load, popped codes and ADM scolded me for trying it. Once you buy their module you can vary the settings on the stock fp.
    Ended up with the Livernois Twin on the stock FPCM blown at 10psi on corn. Barely kept up with demand. Put a Squash return system in it and be done.
