Results 1 to 10 of 10
Thread: What all is needed to repin 98 Vette auto harness to 99-up?
    Baltimore, Md
    1,208
    Anyone done this before?
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Mar 2013
    8
    Yes just finished not that hard, but getting the tune switched over it giving me problems.
    Tuner Howes's Avatar
    Apr 2015
    NH
    130
    connector c1 red 98 vette pinout.
    Pin
    Wire Color
    Circuit No.
    Function
    1–3
    Not Used
    4
    BRN/WHT
    633
    Camshaft Position Sensor Signal
    5–6
    Not Used
    7
    YEL
    400
    VSS Signal High
    8
    Not Used
    9
    PNK/BLK
    1746
    Injector #3 Control
    10–11
    Not Used
    12
    LT BLU/BLK
    844
    Injector #4 Control
    13
    PPL/WHT
    2122
    Injector #2 Control
    14
    DK GRN
    59
    A/C Status
    15
    BLK/WHT
    845
    Injector #5 Control
    16–17
    Not Used
    18
    YEL/BLK
    846
    Injector #6 Control
    19–20
    Not Used
    21
    PPL
    719
    IAT Sensor Ground
    22
    DK BLU
    1225
    Transmission Range Signal B
    23
    LT GRN/BLK
    1745
    Injector #2 Control
    24
    BLK/WHT
    1704
    Sensor Ground Jumper
    25
    PNK
    1224
    Transmission Range Signal A
    26
    BLK/WHT
    771
    PRND A
    27
    RED/BLK
    877
    Injector #7 Control
    28–29
    Not Used
    30
    DK BLU/WHT
    449
    Real Time Damping (W/F45)
    31
    DK BLU/WHT
    878
    Injector #8 Control
    32
    WHT
    776
    PRND P
    33
    BLK
    1744
    Injector #1 Control
    34
    GRY or WHT
    587 or 687
    2nd and 3rd gear Block out Solenoid (M/T) or 3–2 Shift Solenoid (A/T)
    35
    LT GRN
    1222
    Shift Solenoid A
    36
    Not Used
    37
    BRN/WHT
    419
    MIL Control
    38
    Not Used
    39
    DK GRN/WHT
    459
    A/C Clutch Relay Control
    40
    WHT or YEL/BLK
    375 or 1223
    1 to 4 Upshift Lamp Control (M/T) or Shift Solenoid B (A/T)
    41
    PNK/WHT
    1101
    PCM Chassis Pitch Output Circuit
    42
    LT GRN
    1652
    Reverse Inhibit Solenoid Control
    43
    DK/GRN
    335
    Cooling Fan Relay #1 Control
    44
    DK BLU/WHT
    1869
    Crankshaft Position Sensor Signal
    45
    DK GRN/WHT
    428
    EVAP Canister Purge Valve Control
    46
    ORN/BLK
    463
    Desired Torque
    47
    DK GRN/WHT
    762
    A/C Request Signal (C60)
    48
    YEL
    492
    MAF Signal
    49
    PPL
    2121
    Ignition #1 Control
    50–51
    Not Used
    52
    RED/WHT
    2128
    Ignition #8 Control
    53
    RED
    2127
    Ignition #7 Control
    54
    DK GRN/WHT
    2126
    Ignition #6 Control
    55
    DK GRN/WHT
    817
    VSS Output Signal
    56
    DK GRN
    2125
    Ignition #5 Control
    57
    LT BLU/WHT
    2124
    Ignition #4 Control
    58
    LT BLU
    2123
    Ignition #3 Control
    59
    BRN/WHT
    2130
    Ignition Control Reference Low Bank 2
    60
    BRN
    2129
    Ignition Control Reference Low Bank 1
    61
    RED
    1226
    Transmission Range Signal C
    62
    Not Used
    63
    BLK
    407
    A/C Refrigerant Pressure Sensor Ground
    64
    BLK
    452
    Engine Oil Pressure Sensor Ground
    65
    GRY
    773
    PRND C
    66
    YEL
    772
    PRND B
    67
    Not Used
    68
    GRY
    48
    Clutch Switch Signal
    69
    BRN
    1982
    EVAP Purge Vacuum Switch Signal
    70
    Not Used
    71
    PPL
    401
    VSS Signal Low
    72
    BLK/WHT
    451C
    PCM Ground
    73
    GRY
    847
    Extended Travel Brake Switch Signal
    74
    Not Used
    75
    GRY
    720
    Left and Right Fuel Tank Level Sensor Ground
    76
    BLK/WHT
    451H
    PCM Ground
    77
    PPL
    420
    Cruise/TCC Brake Switch Signal
    78–80
    Not Used
    connector c2 blue 98 vette pinout
    Pin
    Wire Color
    Circuit No.
    Function
    1
    TAN
    1671
    HO2S Signal Low Bank 2 Sensor 2
    2
    TAN/WHT
    1669
    HO2S Signal Low Bank 1 Sensor 2
    3
    Not Used
    4
    RED
    631
    Camshaft Position Sensor B+ Supply
    5
    TAN
    1667
    HO2S Signal Low Bank 2 Sensor 1
    6
    TAN/WHT
    1653
    HO2S Signal Low Bank 1 Sensor 1
    7
    RED/BLK
    380
    A/C Refrigerant Pressure Sensor Signal
    8
    TAN
    472
    IAT Sensor Signal
    9
    Not Used
    10
    DK BLU
    1936
    Fuel Level Sensor (Left Tank) Signal
    11
    GRY
    23
    Generator F Terminal
    12
    LT BLU
    1937
    Fuel Level Sensor (Right Tank) Signal
    13
    YEL/BLK
    1227
    Transmission Fluid Temperature Sensor Signal
    14
    ORN/BLK
    1057
    Transmission Fluid Temperature Sensor Ground
    15–18
    Not Used
    19
    PNK
    239
    PCM Ignition 1 Feed
    20
    ORN
    340B
    PCM Battery Feed
    21
    BLK/WHT
    451F
    PCM Ground
    22
    YEL/BLK
    1868
    Crankshaft Position Sensor Ground
    23
    Not Used
    24
    BLK/WHT
    1704
    25
    BRN
    718
    ECT Sensor Ground
    26
    ORN/BLK
    469
    MAP Sensor Ground
    27
    Not Used
    28
    DK BLU
    473
    Engine Cooling Fan Relay #2 and #3 Control
    29
    Not Used
    30
    BRN
    436
    AIR Pump Relay Control
    31
    PPL
    421
    AIR Solenoid Relay Control
    32
    TAN/BLK
    422
    TCC Enable Solenoid
    33
    BRN
    418
    TCC Control (PWM) Solenoid Control
    34
    Not Used
    35
    WHT
    121
    Engine Speed (Tach) Output Signal
    36
    LT BLU/WHT
    1229
    Transmission Fluid Pressure Control Solenoid Control Low
    37
    DK GRN/WHT
    465
    Fuel Pump Relay Control
    38
    Not Used
    39
    RED/BLK
    1228
    Transmission Fluid Pressure Control Solenoid Control High
    40
    TAN/BLK
    464
    Torque Delivered
    41
    PPL
    1670
    HO2S Signal High Bank 2 Sensor 2
    42
    PPL/WHT
    1668
    HO2S Signal High Bank 1 Sensor 2
    43
    Not Used
    44
    GRY
    598
    Fuel Level Sensors 5.0 Volt Feed
    45
    GRY
    596
    Engine Oil Pressure Sensor 5.0 Volt Reference
    46
    PPL
    1666
    HO2S Signal High Bank 2 Sensor 1
    47
    PPL/WHT
    1665
    HO2S Signal High Bank 1 Sensor 1
    48
    LT GRN
    432
    MAP Sensor Signal
    49
    YEL
    410
    ECT Sensor Signal
    50–52
    Not Used
    53
    TAN/WHT
    331
    Engine Oil Pressure Sensor Signal
    54–57
    Not Used
    58
    DK GRN
    1049
    Serial Data Class 2
    59
    Not Used
    60
    BLK/WHT
    451E
    PCM Ground
    61
    ORN
    340C
    PCM Battery Feed
    62
    LT GRN
    1867
    Crankshaft Position Sensor B+ Supply
    63
    Not Used
    64
    GRY
    416
    MAP Sensor 5.0 Volt Reference
    65
    Not Used
    66
    GRY
    474
    A/C Refrigerant Pressure Sensor 5.0 Volt Reference
    67
    Not Used
    68
    LT BLU
    1876
    Knock Sensor (KS) Rear
    69
    DK BLU
    496
    Knock Sensor (KS) Front
    70
    PNK/BLK
    632
    Camshaft Position Sensor Ground
    71
    TAN
    800
    TAC Module Serial Data
    72
    ORN/BLK
    1061
    73–75
    Not Used
    76
    BRN
    1174
    Oil Level Sensor Signal
    77
    RED
    225
    Generator L Terminal
    78–80
    Not Used
    Apr 2015
    NH
    130
    2000 vette c 1 blue
    51
    DK BLU
    496
    Knock Sensor Signal Front (KS1)
    52
    Not Used
    53
    ORN/BLK
    1057
    Transmission Temperature Sensor Ground
    54
    ORN/BLK
    469
    MAP Sensor Ground
    55–56
    Not Used
    57
    ORN
    340
    PCM Battery Supply
    58
    DK GRN
    1049
    Serial Data
    59
    Not Used
    60
    BLK
    407
    61
    PNK/BLK
    632
    62
    GRY
    847
    63
    BLK
    452
    64
    Not Used
    65
    PPL
    1670
    66
    PPL
    1666
    67
    Not Used
    68
    PPL/WHT
    1668
    69
    PPL/WHT
    1665
    70
    BRN
    1174
    Low Oil Level Switch
    71
    Not Used
    72
    YEL
    772
    PRND B Input Signal
    (Automatic Transmission Only)
    73
    BRN/WHT
    633
    Camshaft Position (CMP) Sensor Signal
    74
    YEL
    410
    Engine Coolant Temperature (ECT) Sensor Signal
    75
    Not Used
    76
    BLK/WHT
    845
    Injector 5 Control
    77
    DK BLU/WHT
    878
    Injector 8 Control
    78
    Not Used
    79
    GRY or WHT
    587 or 687
    2nd and 3rd Gear Block Out Solenoid Control (M/T) or 3–2 Shift Solenoid Control (A/T)
    80
    BRN
    718
    Engine Coolant Temperature (ECT) Sensor Ground
    c2 red 2000 vette
    Pin
    Wire Color
    Circuit No.
    Function
    1
    BLK/WHT
    451
    PCM Ground
    2
    BRN
    418
    TCC Control Solenoid
    3
    Not Used
    4
    PPL
    421
    AIR Solenoid Control
    5
    TAN/BLK
    464
    Torque Delivered
    6
    RED/BLK
    1228
    Transmission Fluid Pressure Control Solenoid High
    7
    Not Used
    8
    LT BLU/WHT
    1229
    Transmission Fluid Pressure Control Solenoid Low
    9
    DK GRN/WHT
    465
    10
    WHT
    121
    11–13
    Not Used
    14
    RED/BLK
    380
    15
    RED
    225
    Alternator L Terminal
    16
    Not Used
    17
    DK GRN/WHT
    762
    A/C Request Signal (C60 only)
    18
    DK GRN
    59
    A/C Status Signal
    19
    Not Used
    20
    PPL
    401
    Vehicle Speed Sensor (VSS) Reference Low
    21
    YEL
    400
    Vehicle Speed Sensor (VSS) Signal
    22–24
    Not Used
    25
    TAN
    472
    IAT Sensor Signal
    26
    PPL
    2121
    Ignition Control 1
    27
    RED
    2127
    Ignition Control 7
    28
    LT BLU/WHT
    2126
    Ignition Control 6
    29
    DK GRN/WHT
    2124
    Ignition Control 4
    30
    Not Used
    31
    YEL
    492
    MAF Sensor Signal
    32
    LT GRN
    432
    MAP Sensor Signal
    33
    DK BLU
    473
    Engine Cooling Fan Relay 2 and 3 Control
    34
    DK GRN/WHT
    428
    35
    Not Used
    36
    BRN
    436
    37–38
    Not Used
    39
    RED
    631
    40
    BLK/WHT
    451
    PCM Ground
    41
    Not Used
    42
    TAN/BLK
    422
    TCC Enable Circuit
    43
    DK GRN/WHT
    459
    44
    LT GRN
    1652
    45
    WHT
    1310
    EVAP Canister Vent Valve Control
    46
    BRN/WHT
    419
    Malfunction Indicator Lamp (MIL) Control
    47
    WHT or YEL/BLK
    375 or 1223
    1 to 4 Up-shift Lamp Control or Transmission Shift Solenoid B
    48
    LT GRN
    1222
    Transmission Shift Solenoid A
    49
    Not Used
    50
    DK GRN/WHT
    817
    Vehicle Speed Output Circuit
    51
    YEL/BLK
    1227
    Transmission Temperature Sensor Signal
    52
    GRY
    23
    Alternator F Terminal
    53
    Not Used
    54
    DK BLU
    1936
    Fuel Level Sensor Signal
    55–56
    Not Used
    57
    PPL
    719
    IAT Sensor Ground
    58
    TAN/WHT
    331
    59
    Not Used
    60
    BRN
    2129
    61
    BRN/WHT
    2130
    62
    GRY
    773
    PRND C Input Signal
    63
    PNK
    1224
    64
    DK GRN
    890
    Fuel Tank Pressure Sensor Signal
    65
    Not Used
    66
    PPL/WHT
    2128
    Ignition Control 8
    67
    RED/WHT
    2122
    Ignition Control 2
    68
    DK GRN
    2125
    Ignition Control 5
    69
    LT BLU
    2123
    Ignition Control 3
    70–72
    Not Used
    73
    LT BLU
    1937
    Fuel Level Sensor Signal (Secondary)
    74–80
    Not Used
    Baltimore, Md
    1,208
    ANy issue like fuel sending unit not reading right, etc?
    Baltimore, Md
    1,208
    If you had to guess time on repinning what would it be?
    Need 99-up connectors, cheapest way to get them?
    Apr 2015
    NH
    130
    junk yard prolly still plugged in to the ecm you need.....at least that's how lkq operates around here a lot of times.
    Apr 2015
    302
    https://www.eficonnection.com/eficon...spx?ItemId=286
    Pricey though...almost $120.. for a complete set
    I bought my ecu pins from Mouser and was happy with them, but I didn't see the connectors on their site
    Apr 2015
    NH
    130
    mouser is a great terminal source.
    Baltimore, Md
    1,208
    I just thought about this. Guy plugged in a 99 vette harness and ECU so the damn pcm pin side is fine. The pinouts I actually need to look at is the engine to chassis harness interface!
