Results 1 to 5 of 5
Thread: LS2: setting commanded A/F and TM
    We're tuning a 2005 C5 and the timing retard between gears is crazy. How do you eliminate torque management without removing traction control? Secondly, how do you set the commanded A/F for a SD tune? Open Loop Gas looks like its what you change..
    Phil
    Phil
    1999 Corvette Coupe
    Worlds Fastest 346" N/A Coupe
    ProStreet Motorsports
    HP Tuner SD specialist All GM Vehicles
    2000 Mustang 438" LSx 4.70 @ 164
    NEW 346" N/A testing: 10.4 @ 132.4 N/A(875')
    NHRA Corrected: 10.21 @ 134 N/A
    Old Nitrous Best: 10.0 @ 138.89(181 DA)
    shift torque reduction, under Trans -> Tq Mgt
    The commanded AFR is set by the PE table and openloop tables. Be aware that GM uses a couple of methods on the openloop tables, sometimes they use the base table and set the multipliers to 1.0, in other cases they set the base to a fixed value and use the multipliers.
    Chris...
    I count sheep in hex...
    Nothing under that table on the 2005 corvette....
    Phil
    1999 Corvette Coupe
    i just realised this in an M6, what do you mean timing retard between gears? When you lift the gas for the shift the timing will naturally retard.
    Feb 2006
    Lenexa, Kansas
    17
    Quote Originally Posted by Chris@HPTuners
    yeah, that is exactly what I am looking for now. I want to do this w.o removing traction control.
    2005 GTO Quicksilver/Black M6
    COMP 224 112 lsa, Patriot Xtreme Gold Springs, TSP pushrods; Kooks LTs; King Springs F/R; GMM Street w/LSS; custom h-pipe w/ 3" Dynomax Bullets; HP Tuners
    http://community.webshots.com/user/jdo669
