anybody make an easy quick connect to do a pcm swap on a 98...
to make it a 2002 PCM??
I might be aquiring a 98 A4..and want to put a 2002 PCM in it
-Scott -
These folks may have what you want in the harness department...
http://www.currentperformance.com/eng_mgt.html
The word 'may" is because I looked at the difference in pin outs, sensors and body module. This may be a real challenge.
As for the PCM, the 1999 thru 2002 use the 12200411. Just pick an appropriate VIN and have it flashed. But you new that one..
We modify harnesses but have not been asked for this 98 to 99-02 conversion. I believe a stand a lone harness would be the answer if the sensors are compatible..
Dave
just go with speartech if you want to do a new harness.
98 Camaro, M6, HPTuners, heads and cam
reason I ask is cause I might be getting a 98 thru a trade deal with somebody who wants an almost stock six speed(which I have) and I'd be getting a 98 A4....adn I'm not dealig with a crappy 98 computer..I gotta have SD for what I want to do
so I need a 99-02 pcm for it
I have wiring diagrams...but I dont really want to go there..LOL
-Scott -
you can cross up the pinouts, swap coolent sensors and get it done.
but noone makes an off-the-shelf solution.
1991 Camaro Convertible with 02 LS1
I'm just looking for a pcm pin swap quick connect...I just dont want to be the guy that has to solder/crimp 200 connections..I already know I need to replace a few sensors...
-Scott -
Originally Posted by soundengineer
i know exactly what you want...
the only shop i know that does that sort of thing, and would have the female 98 connectors to make it a actual plug swap would be speartech.. someone else might also have the connectors, but i donno where.
you can call steve spears and ask him how much for a crossover harness, but my guess would be atleast $300... he isnt cheap. lol.
if you wanted to do it yourself, you could use a trashed 98 computer, salvage/dremel the connections, ect..... good bit of work
in the FAQ at the top of the conversion/hybrid forum on LS1tech, you'll find both the 98 and the 99-02 PCM pinouts.
