vehicle will occasionally die at parking lot speeds
Vehicle is a 2014 Raptor with D1SC and Stainless Works 1 7/8" Long Tubes with Cats. The only mechanical difference between the two tunes is Long Tube Headers. The original tune is when the vehicle had factory manifolds. The vehicle did not have this problem before. What did I change that would now make the vehicle occasionally die around 5mph when coming to a stop?
Your 02 transport delay is unchanged between the two tunes. Generally the O2 location is moved further downstream with long tubes and the there must be changes made in the tune to compensate for it. Look at engine>fuel>Open & Closed Loop>Transport Delay. I don't have headers on my car, but I'll fish around and see what I can find, I think people start by adding 25%, but hopefully someone who has done long tubes on one of these can chime in. Pull a log too so people can see whats happening at the time of stall if possible.
If it were my truck and I wanted to play with this I would try this:
1. set idle rpm to 850
2. engine>fuel>open&closed loop>load minimum set to .05
3. engine>fuel>open&closed loop>time minimum set to 0
4. engine>fuel>open&closed loop>seconds maximum set to 2
5. engine>fuel>ope &closed loop > transport delay multiply the whole table by 1.35
