Solved a lot of issue so far with this car, the list is getting shorter and the worst of it is trying to cold start the car. Gasoline not E85 or anything, but cold if you crank it itll burp once, recrank might burp twice or run a second, recrank and run for a while die, then pick up fine the next time you crank it at least thats how it usually acts
Pretty common E85 cars act like that, usually lean at cold start, but Ive tried adding and subtracting from the Cranking FA Mult tables to no avail. Tried throwing more and more startup airflow at it as well. No changes really. Tried adding subtracting timing cranking. No changes. Am I sitting on a max value for startup airflow cold? I wish there was a desired idle airflow and an actual value to see if there was a discrepancy over what it is trying to do
