Results 1 to 7 of 7
Thread: need help with a performance tune
    Jun 2014
    18
    im tuning a 1999 Silverado with 4.8 or 5.3.. still fairly new to hp tuners. Im turning off the theft deterent on it , but he also wants a tune in it for added performance but nothing too radical. Wheres the best place to start? what should I tweek for a little added performance?
    13,565
    Lots of minor stuff can be done.
    Shorten the shift time, add 5-10% to the shift pressure for faster and better shift feel, install a corvette servo is almost a must on those trucks.
    Under the PE stuff, you can lean it out a tad as they run em pretty rich, lower the PE delay or get rid of it and set the PE cold/hot to a lower number instead of like 80% throttle. I prefer 35-45% throttle and increase the ramp in rate to 1-1.5, that will make it feel alot better.
    If he really wants more done, he should upgrade the OS to a newer truck, the 99 pcm's OS arent that great at all. You can read up on that though.
    Jun 2014
    18
    thank you... exactly how do I lean it out though? I don't see a map in PE to adjust AFR
    Apr 2011
    russia
    36
    ^ under PE tab theres a table called EQ ratio, its a multiplier and the way you set its by making a simple division ie: your stoich afr is 14.63 and you want a 12.5, 14.63/12.5= 1.170 *put this value on the table for target afr
    Jun 2014
    18
    thank everyone for there help. that helped a lot. I changed eq ratio map in PE. what would be the best thing to change at cruising speeds for added fuel economy?
    Apr 2011
    russia
    36
    reading and smart driving .... bad idea doing both at the same time btw.
    http://www.hptuners.com/forum/showth...y-Tuning-Ideas
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    301
    What he said. Do a LOT of reading. Make small changes. Understand what the change does and what you need to log to understand whether the change was good or not. For example, changing the PE EQ ratio, as mentioned, can make the car run leaner at WOT. Understand what that eq ratio is and what changing it does. The equation is simple, but know it so you change it the correct direction and by an appropriate amount. Know what to log to ensure that you arent getting KR and need to adjust timing, etc.
    Kenne Bell Supercharged 2003 Corvette Z06
