Results 1 to 8 of 8
Thread: 2010 camaro v6 3.6 twin turbo tuning
    Tuner Ls3sierra406's Avatar
    Jul 2011
    Texas
    51
    Anyone tuning 2010 camaros 3.6 v6 I'm getting a few codes any help it has twin turbo boosting 5-6 psi intercooled and I'm getting codes p0101,p700 & p069e any help would be appreciated.
    28,266
    P0101 is a maf code
    p069e I believe is a fuel pump control module code(I don't believe this is controlled by the pcm)
    Advanced Tuner caesar's Avatar
    May 2003
    227
    Quote Originally Posted by Ls3sierra406 View Post
    You have not adjusted your MAF/airload tables for the [significantly] increased airflow.
    P0700 is a TCM forwarding code which means your TCM is letting you know that there is a transmission code stored.
    Same for P069E, you've got some issues with the FCM.
    Jul 2011
    Texas
    51
    Do we have a config.for that 2010 computer to data log MAF?
    Jul 2011
    Texas
    51
    And no I have not corrected MAF airload tables it is being used as blow thru style and I dont see a data logger for that PCM.
    Jul 2011
    Texas
    51
    This is a project inprgress does my file look some what okay or am I lacking on some areas of the tune? The P0700 & E069 when I disabled catylist heating car is cat less and has turbos mounted under car and we have a front mount intercooler intake temp stays efficient.
    Feb 2006
    South Carolina
    1,525
    You have to create your own config. For logging, in many cases. Or, at least modify an existing one.
    Jul 2011
    Texas
    51
    Okay thanks
