Just wondering if a 2000 OS be flashed into a 99 pcm to get the 3 bar option?
TIA!
TIA!
GO RAIDERS!!!!!!!!!!
02 C5 Z06
8.8@160
Do you mean an LS1 PCM? If so, yes, and to be honest, I'd go with a 2002 OS...12212156 is I believe the newest OS you can put into a 99-2002 LS1 PCM.
2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
2023 Durango Hellcat
It's weird I tried it last night and it did not work. I noticed the security light stayed on on the dash. Car would fire for a second then shut off. Loaded the 2 bar back in and it fired right up.
02 C5 Z06
8.8@160
Post what you flashed in. If you don't have the MAF fail stuff set correctly, it'll start/stall instantly like that.
Do you just want a 3-bar capable 99 operating system? Is this for a F-body?
http://www.dsxtuning.com
Just say no to bull s***.
Not all '99 ECMs are created equally. My early '99 Corvette's ECM is not the same as the later '99 ECM that I use in my Nova and they have different enhanced OS choices. You may not be able to run 3-bar OS if you have one of the early ECMs.
