Results 1 to 20 of 20
Thread: Why is this MAF maxed out
    Baltimore, Md
    1,211
    D1SC car, 408 G8. switched to LS7 maf card in a 3.5 tube with the sensor pulled out near the edge of the tube, supposed to lose resolution but extend range but this thing is 15000 hz at 5000 rpm.
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Sep 2008
    1,668
    The tune can't change the frequency reading for a given airflow, it can only change how much air the computer thinks that frequency is. Why not use a 4" / ~100mm tube?
    2023 Durango Hellcat
    Baltimore, Md
    1,211
    Because it doesnt fit the plumbing, and DSteck said his was able to make @1000 hp with a 3.5 tube and LS7 maf car with blower, so why is this so much different?
    I saw little to no range increase going from a stock G8 MAF to this setup anyway, whats to say their will be enough range with a 4 inch tube... Is going from 3.5 inch pipe to a short section of 4 inch (that wont fit anyway) and back to 3.5" going to get 50% more range I dont anyway. I want to know why this reads so many Hz under all situations
    Sep 2008
    1,668
    What frequency does the sensor read key on engine off?
    Nov 2009
    All Around
    3,149
    is your maf pull through or draw through placed?
    Baltimore, Md
    1,211
    blow through
    Baltimore, Md
    1,211
    it reads 0 Hz key on engine off
    Just put in a larger diameter tube. 4" or 4.5"
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    5BA8
    3,431
    Take a pic of the location and tubing in front and in back and post it. Depending on the sensor's location within the pipe, it may be susceptible to higher airflow. Doing nothing more than clocking it slightly different can greatly increase or decrease the sensor's range. That's the same principle as pulling the sensor out so the element is nearer the edge.
    email=[email protected]
    Baltimore, Md
    1,211
    Because it doesnt fit, I mentioned that earlier
    Quote Originally Posted by Mike@G-Force View Post
    Nov 2009
    All Around
    3,149
    can you place the sensor to be pull through configuration i believe that would solve your issue.
    Baltimore, Md
    1,211
    not really
    Quote Originally Posted by GrannySShifting View Post
    Why dont you just SD tune it? Its super easy!
    G-FORCE Motorsports
    www.gforce-tx.com
    [email protected]
    Baltimore, Md
    1,211
    LOLOLOLOLOL
    I would have from jump street but customer bought a MAF flow referenced alky kit so I was trying to use it like that based on the fact that DSteck said his only read 13200 hz peak at 900-1000 hp with a similair 3.5 tube LS7 card setup
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Dunno what to tell you. Made 1200+ whp on a F1X C6Z at 14,500Hz in a 3.5" tube.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jun 2008
    Charleston, SC
    969
    between 0 - 34000 frames, I didn't see it get even close to 15,000 hz
    -Carl
    Baltimore, Md
    1,211
    Figured out the issue with this one, was a doozy. The fool that put the alcohol kit in originally left a bunch of extra wire stuffed under the cowl. Every time you used the wipers, it rounded up some more wire. Was shorting it to ground stretched bare in some sports dumping some of the signal I guess, till it eventually finally broke and stopped reading.
    Aug 2009
    Calibrating
    3,377
    Thanks for posting
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2006
    Detroit
    1,033
    LOL, "find the mechanical problem!" What actual airflow (unscaled) are you at now and at what MAF frequency near peak power?
    FWIW, I also see that you have a change in diameter just before the MAF too. My experience with the housings that shift the MAF element outward (like yours does) to open up the middle is that they can have a hard time with changes in diameter. This is because the sensing element is closer to the wall, right where you sometimes get eddies in the flow if the diameter change is too abrubt and close to the meter. For me, changing to a smaller MAF housing (going from 4" down to 3.5" which was the same as the rest of the tubing and the throttle) that didn't have a diameter change upstream of the MAF element fixed everything.
    Feb 2006
    Canada
    1,963
    Wipers causing fueling problems.... now I have actually seen it all!
    I know, wires pulled by it, but still... hahaha
    2000 Trans Am WS6
