http://www.hptuners.com/forum/showth...9A-ECM-support
What this means to you:
- If you own or know someone that owns a vehicle that uses one of these pcm's do a read entire using the newest public build 2.24.105 or newer and send us the .hpt file as well as a vcm suite infolog so that we can start mapping these calibrations.
- Upon reading out the pcm you will likely receive a "File failed validation check" error or "definition failed to load", don't worry, its perfectly normal, just send us the file & infolog, those errors are perfectly normal.
Where do I get this update?:
- Right on your customer page www.hptuners.com/customers even though the 2.24 link is dated for march something its autoupdated with any new compiles we create so simply download & install.
What if I get some other error?:
- Email support with a screenshot of the error along with a vcm suite infolog while connected to the vehicle in question
What vehicles does this E92 pcm cover?:
- 2014 Chevy Corvette
- 2014 Chevy Silverado V8
- 2014 GMC Sierra V8
- There are likely others this is just through our initial research of these pcm's though I'm sure this extends to others.
