Results 1 to 13 of 13
Thread: 1 OR 2 Wideband O2
    Aug 2004
    9
    1 OR 2 Wideband O2
    1 OR 2 Wideband O2
    This has been bugging me alittle. using only one Wideband O2 say on driver side for tunning. how do you know the the other side is also ok without a Wideband O2 .
    any of the AFTERMARKET Wideband O2 controls support DUEL SET UP?
    Mar 2004
    34
    Re: 1 OR 2 Wideband O2
    AEM has a dual sensor setup. I don't know if its necessary or not though.
    Aug 2004
    9
    CAN HP LOG BOTH? IF I WERE TO GET TWO WIDEBAND O2'S.
    Advanced Tuner arthansen's Avatar
    Apr 2004
    Tampa, FL
    425
    If it has two outputs, HP Tuners can log both!
    2013 Jeep Wrangler JK
    3.6 V6
    More MODs than Stock
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Apr 2004
    Bakersfield, CA
    592
    Sure it would be best to have an O2 on each side, but I think the normal setup with one sensor is right after the Y pipe if you don't have true duals.
    Eric - 01 Silverado 5.3 ECSB
    ET: [email protected] 1.77 60' 5200 lbs
    Crappy website about my truck
    My Myspace page
    Usually contains explicit material (language, etc..)
    It's Peanut Butter Jelly Time!
    Jul 2004
    orangeburg s.c.
    17
    :huh2: and if you have true dual where do you put it
    Oh yeah
    Apr 2004
    Bakersfield, CA
    592
    Quote Originally Posted by blackss1316
    You can put them anywhere before you cats if you have true duals.
    My Myspace page
    Apr 2004
    Tampa, FL
    425
    We are about to install a WBO2 in a friends car and what we plan on doing is trying it in both sides then leaving it in the leaner side. This way you tune to the leaner side, thus safer.
    3.6 V6
    2018 Ram rebel
    5.7 Hemi V8
    Stock
    Apr 2004
    Bakersfield, CA
    592
    Good idea, wish I could've had more say in the placement of mine.
    My Myspace page
    Sep 2004
    4
    I have a question that sort of applies to this. Can I put the wideband sensor in my narrowband bung? If I do this is there a way in HPT to force it to go to closed loop? I believe it will not if there is no front O2 sensor hooked up to the ecu.
    I will get 2 sensors if I can use the existing bungs otherwise I have a space issue.
    Thanks for any help
    Matt Jelinek
    Apr 2004
    Bakersfield, CA
    592
    Most widebands have a narrowband output for this very reason. You can connect the narrowband output to the stock ECU and it will function as if the stock O2 was still there.
    My Myspace page
    Jan 2005
    Texas
    18
    Im not running cats. Can I just use the bungs that use to be after the cats for the wideband. I mean its just straight pipe anyway or would that be to far back?
    Indianapolis
    166
    Quote Originally Posted by landlord
    That'll work. Many dyno's get WBO2 by putting a clip on bung in the tailpipe, so the rear O2 position will be fine.
    2002 Z51 C5 MN6 Coupe&&SuperMaxx Headers, Vararam, Ti Exhaust
