Results 1 to 5 of 5
Thread: Is this scanner Fast?
    Jan 2004
    1
    I remember using autotap when monitoring o2's and such it would take so long to update and you could only monitor a few things at a time for it to be fast enough.
    Is this a problem with autotap software or the pcm itself being slow?
    Is your program slow like this?
    Re: Is this scanner Fast?
    10frames/s with 24 things to log.
    Sep 2002
    Chicago, IL
    6,397
    Thank you Highlander, that is exactly correct.
    Our stuff is very fast.. even logging the max of 24 values its very fast.. if you bring the number of "bytes" you use to log down to 12, you will get twice as much data... if you bring it down to 6 you will get 4 times as much data! It FLIES!!
    We got this guy Not Sure, ...
    I thought the limit was 10f/s with 24.. you couldn't go faster than that with less PIDs ...
    Sep 2002
    Chicago, IL
    6,397
    They aren't really "frames", more so channels.
