Results 1 to 9 of 9
Thread: scanner portion of suite
    Jan 2004
    Kitchener, Ontario, Canada
    19
    Utilizes GM's Fast Packet Technology
    Standard Table Display
    Graphical Gauge/Dash Display
    Graphical Chart Display
    Read/Clear DTC's in just seconds
    Logging and Playback
    VCM/PCM Command Controls
    but how does it compare to autotap enhanced? logging & playback of what parameters? basically i want to know if i can get rid of my autotap enhanced, or am i still going to want to use autotap for more "in-depth" diagnostics? thanks!~
    --matt
    EDIT: for my fbody l36
    Sep 2002
    Chicago, IL
    6,397
    Re: scanner portion of suite
    I'm not familiar with autotap advanced.
    Our scan tool can log and play back a great deal of PID's, more than enough we believe to get the job done. If you feel that our scan tool software is lacking in any way we can always update it to suit the users needs.
    We got this guy Not Sure, ...
    Jan 2004
    19
    what are PID's? ;D
    Autotap Generic Parameters: can be found here:
    http://www.autotap.com/generic_parameters.asp
    Autotap Enhanced Parameters:: can be found here:
    http://www.autotap.com/enhanced_parameters_gm.asp
    main things i'm interested in seeing in the suite besides the obvious o2 mV & timing degrees, are any KR & specific misfire data--which cylinder & total misfires per cylinder. also injector pulse rates, fuel trims, yadayada.
    --matt
    Sep 2002
    Chicago, IL
    6,397
    Oh yea we definately support many more than just the SAE standard PID's..
    For example, our dash display shows:
    MAF
    MAP
    RPM
    MPH
    ECT
    IAT
    KR
    Advance
    TP%
    O2 B1 S1
    INJ B1
    O2 B2 S1
    INJ B2
    LT FT B1
    ST FT B1
    LT FT B2
    ST FT B2
    Jan 2004
    Toronto, Canada
    21
    Will it allow the user to "scan" any GM vehicle or does the software restrict it to the model year that was purchase?
    \'98 Grand Prix GTP&&[email protected]&&(bottle fed)
    Feb 2004
    Hopewell, VA
    6
    Quote Originally Posted by Magnus
    MAF
    MAP
    RPM
    MPH
    ECT
    IAT
    KR
    Advance
    TP%
    O2 B1 S1
    INJ B1
    O2 B2 S1
    INJ B2
    LT FT B1
    ST FT B1
    LT FT B2
    ST FT B2
    And you can record this right? (Not just a dashboard)
    2001 Trans-Am - A4 w/2.73 Steel Driveshaft &&Mods: FTRA, K&N filter, High-Flo Air lid, TBB, Venom VCN-2000 N2O, Comp 224/228 Nitrous Cam, SVO 30# injectors, 255LPH Walbro pump, Yank 3000 TT w/2.5 STR
    Sep 2002
    Chicago, IL
    6,397
    You can scan most GM vehicles.
    Yes we do offer recording and playback.
    Feb 2004
    Hopewell, VA
    6
    Great! Will it export out to a comma delimited file or other common format? Just in case I need some help from other tuners.
    Sep 2002
    Chicago, IL
    6,397
    Sure will.
