Results 1 to 3 of 3
Thread: anyone w/ plx?
    Las Vegas, Nv
    64
    anyone w/ plx?
    Just wondering how you had to wire it to the pigtail. I ran my white cable to the white on the EIO and the logger read 12.65 all the time. I then connected the ground on the EIO to a ground on the car. It still reads 12.65 all the time.
    What am i missing? The PLX device has it own 12v/Ground for the unit and a wideband output (white) narrowband output (gray)
    2000 Trans Am WS6 - Bright Red : 12.36 @ 110 - 1.832 60
    228/232 .571/.588 113 LSA | JetHot LTs | Yank ST3500/2.5 | SLP lid
    Mar 2004
    34
    Re: anyone w/ plx?
    Are you using the space directly under the "intake air temp(sae)" on the default config table view? At first I wasn't, and had the same problem you are having. Each of those blank spaces is assigned a different lead on the pigtail.
    Las Vegas, Nv
    64
    Re: anyone w/ plx?
    Quote Originally Posted by eatme
    i was actually using the one that was just below that:
    intake air temp
    blank
    plx
    I'll give that a try - thanks
    edit: it worked great
