Results 1 to 17 of 17
Thread: Need Help reducing Knock Retard
    Banned
    Apr 2011
    Usa
    36
    2008 Corvette LS3 Auto 6 speed
    Car only has a Cam 225/230 113 LSA new springs and rods.
    Factory NPP Exhaust w/ Factory X Pipe
    Got a Mail order tune that wasnt to par so my friend and I began to work on everythihg.
    Car is still running very rich at WOT low to mid 11's AFR
    in Open Loop it is rich under 2k RPM too.
    On my scanner I see a lot of knock retard
    so my friend and I tried to lean her out and couldnt...
    we adjusted the MAF table and VE table and it didnt make a difference.
    How do I lean the car out so I can get my 12.5 AFR at WOT.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Try my attached thumbnails.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Aug 2010
    Roswell, N.M.
    1,956
    Timing is a different story, that could be BKR or anything else. Is the knock audible?
    618/618 motor
    906/862 spray
    Banned
    Apr 2011
    Usa
    36
    Quote Originally Posted by IDRIVEAG8GT View Post
    What is BKR? The knock is not audible but im sure that and the timing have something to do with me running rich.
    Aug 2010
    Roswell, N.M.
    1,956
    Burst Knock Retard. It's a prediction coefficient concerning where timing should be pulled.
    618/618 motor
    906/862 spray
    May 2008
    Wichita, Kansas
    147
    we adjusted the MAF table and PE table and it didnt make a difference. How do I lean the car out so I can get my 12.5 AFR at WOT. Knock is not something we need to wrry about right now untill the fueling is right, I only saw 1 deg of retard on our WOT run. Also I am using a LM2 calibrated wodeband.
    Correction^^, I could not figure out how to alter his VE table, it was all zero'ed out, he is on MAF only right now, lowering the PE table did nothing and lower the MAF table did nothing so I am stumped on how to make his WOT afr leaner, I am used to the Gen III tuning (my car) but the gen IV's have about 1.5 times as many tables. His OL afr from idle to 2k is in the low 13's, car fully warmed up.
    2015 Yukon SLT 5.3
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Ls1c5vette View Post
    I figured that you guys didn't go enough. I tried 10% off just for fun. I'm doing some research here on why the changes would take no effect.
    In essence you might simply want to try a Write Entire.
    618/618 motor
    906/862 spray
    May 2008
    Wichita, Kansas
    147
    I thought it was not a good idea to do a write entire? Hope we dont have to do that every time cause its about 5 mins a pop!
    2015 Yukon SLT 5.3
    Sep 2008
    LI NY
    104
    The eq% vs rpm ratio(in fueling,power enrichment) should be set at 1.150 for all rpms(this will give you 12.60 commanded AFR)...then put you MAF setting back to stock. Invest in a wideband to properly watch/adjust your afr using MAF from now on.
    Aug 2010
    Roswell, N.M.
    1,956
    i know it sounds totally unethical, but when trying to change AFR on my Silverado, no matter what I did it stayed the same until I did a Write Entire. It was sooo weird, but try it, or do what FASTRUK says.
    618/618 motor
    906/862 spray
    May 2008
    Wichita, Kansas
    147
    Doing this will force PE 100% of the time will it not? I dont understand why all those tables are zeroed out.
    2015 Yukon SLT 5.3
    May 2008
    Wichita, Kansas
    147
    ^^Makes sense now, we will try that this weekend. So him being a MAF only tune ALL I need to do is set the PE, and then scale the MAF table accordingly to compensate to rich/lean during WOT, correct??
    2015 Yukon SLT 5.3
    May 2008
    Wichita, Kansas
    147
    Bump for question above ^
    2015 Yukon SLT 5.3
    Aug 2010
    Roswell, N.M.
    1,956
    Yes sir. You are correct. Don't give yourself a brain aneurism doing this. Remember you're too rich, not lean. And you aren't rich enough to foul plugs.
    You guys are doing good, no worries!
    618/618 motor
    906/862 spray
    Jun 2007
    Huntsville, Ontario
    6
    On those PCM's you have to do a write entire every time. My tbss was a pain.
    2007 tbss, cai, hptuners
    Feb 2010
    400
    Bump for write entire on E40 PCM is this necessary?
