Is there a way to command a tune to stay in idle control/ fuel trim cell 20 until a defined TPS % is met?
A quick recap as to why I need this to happen. I have a 2001 Camaro with a 408 and powerglide. Since we put the PG in it, the TPS works it's way up to 2% at idle and falls into FTC22 which kills all adaptive idle spark control. It was not an issue until we installed the new Big A$$ Baby Huey cam. It idles great until the tps sees 2% and it falls into FTC 22. Then the timing locks into the appropriate timing cell and the idle goes to crap. I have done the obvious and I'm not sure there is a way to manipulate the tune, but I'm up for trying anything at this point.
Mechanically, I have checked and added all grounds, tried 3 different NEW TPS sensors as well as clocking them. The AFR is happy, the RAF and IAC are dialed in and I have used the VCM controls to find the spark sweet spot, but it wants the adaptive idle controls active to be real stable.
The TPS issue started when when we swapped from the stcok style 4L60E to the PG. the other cam didn't seem to mind staying in FTC22 with the timing locked, but the new big stick is pissed off.lol.
I have commanded a higher idle, but it locks at 1200 rpm for some reason.
This is a drag racing car that is bracket/index specific. It has a 6000 stall and stays above 5800rpm after the hit. I just need it to stay in FTC 20 until after 4% TPS. Please tell me it's possible.
I have attached my tune so you can see that I did all that I can do to get it to stay in FTC 20 with no success.
