If anyone has the time, could they look at my log file and my tune and give any pointers. My 1/4 mile times don't seem too right and I feel I should be 60' alot harder than it is (1.62). This is my second to last pass of the day. I didn't get the last pass logged after I adjusted some of the timing as I was getting some KR.
Car is a '98 TransAm, stock '98 PCM running speed density, 346 c.i., built 4l80e auto w/ FTI 4400 convertor, MWC 9” w/ 4.11 gears, 28” MT drag radials, MS3 cam (234/242 dur @ .050, .603/.609 lift, 113 lsa), PRC stage 1 243 cylinder heads w/ Patriot Performance gold spring kit, SLP underdrive pulley, LS6 intake, TR7 spark plugs and MSD 8.5 wires, Pacesetter 1 3/4” long tube headers and TSP off road y-pipe to a Magnaflow catback, 3” DMH cutout, 42# green top injectors
Best time before the new 4l80e trans was 11.45 @ 119 mph. On this log, I think it went an 11.71 @ 117 mph and 1.65 60'. DA probably wasn't that good but I feel this car should still run better. Car is probably a 100 lbs lighter than stock. Full suspension minus tubular k-member and a arms. Weld alumastars in the front and rear. Getting no wheel spin.
What do you think? Probably needs new driver mod???
