Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: 100 mm MAF intake air temperature reading high
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    For anyone running the card style 100 mm MAF's you have probably noticed that the IAT reads about 15* or so higher than your stock MAF/IAT. HP Tuners gave us a new table in the 512kb & 1024kb LS1 platforms that you can use to adjust the IAT scalar.
    I tried this yesterday and it works great. I lowered the entire stock table by 15% and I ended up within 1* of ambient. Heat soak at stop lights had its normal rise and once moving it drop like it used to with the old 85 mm MAF.
    You need the newest Beta software to do this change. It is in the engine diagnostics section under airflow.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Dec 2004
    Laurel, MD
    1,020
    is it always 15% or does that change in reference to some other variable?
    Oct 2007
    983
    Here is a screen shot of the stock table, it is based on temperature and sensor resistance. I lowered the stock temperature by 15% (select all and multiply by .85) across the board in reference the the resistance in the table.
    LS1 Tuning Guide
    Thanks for the info .
    98 Z28
    stock ls1 engine,A4,Fast 90/90,SLP lid,Ms3 112LSA,LT Headers,TCI 3500stall,semens 60 inj,ASP under drive ,3.73 gear,11.82 1/4 .sold
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    What Beta version are you running?
    Nice since i believe i was the one asking for it in another thread But without THIS thread, how would one know it existed ? Is there a list of "unsupported features in 2.2x" somewhere ?
    I will know ask for my first Beta
    C5-2000 MN6 LS2 block Tony Mamo FAST90+Ported LS2 TB 100mm MAF AFR 205 59cc CompCam 921 Yalla Terra G5X1 LG Pro Headers LG G2+T1 Chassie LG ducts MOVIT brakes - HPT&NGK AFX
    //Sweden
    Señor Tuner MeentSS02's Avatar
    Jun 2005
    Dayton, OH
    1,132
    Awesome...just what I was looking for.
    Oct 2007
    983
    This Beta just came out a couple of days ago.
    2.23.3868.34842
    This is what is in the newest update:
    This beta adds several new features for several platforms
    All platforms receive
    New Editor
    512kb & 1024kb LS1 platforms received
    Options matrix
    Platform type switch
    Fan recirc switch
    TPS High & Low fail constants
    About a dozen new rolling idle tables and constants
    IAT Scalar table
    E38 & E67 pcm’s received
    Roughly 50 new tables described here http://www.hptuners.com/forum/showthread.php?t=28498
    E37 support released
    2009+ Allison TCM support released
    2011 Camaro/Corvette TCM support released
    2010 Savana/Express V8 gas support released
    Dodge Licensing is finished and awaiting final Firmware updates which should be ready soon
    Please vigorously test the MPVI pro standalone datalogging using this new beta(analog inputs are disabled using it) but more specifically the new slow speed mode which should extend logging times for these applications.
    This Beta also produces a new Debug.dat file found in your hptuners-settings folder, this should help with comms problems
    We have posted an updated beta version 2.23 on your customer login page located at
    www.hptuners.com
    LS1 Tuning Guide
    Ugh..I really wanna fix the temp on my MAF. The lowest I EVER see temp wise is about 99*F when its about 83-85 outside. Driving I'm lucky to see under 104*
    It's really messing with my tuning as well. Every time my IAT gets up to 120+ the car goes lean making idle tuning quite difficult.
    I cannot find the beta option anywhere on the site.
    Jun 2005
    Dayton, OH
    1,132
    Quote Originally Posted by Exidous View Post
    You have to email:
    [email protected]
    I just sent them an email today requesting access to this beta - I included the serial number from my interface, so now I will just wait until they get to it.
    Ya I figured as much. :-) That's how I got my last beta just wanted to see if it had changed.
    Sep 2009
    346
    Quote Originally Posted by 69lt1bird View Post
    Would this include purchasing a PowrMaf 100?
    If that is the case... are there any other methods of 'calibrating' the IAT to function properly?
    I do not see the IAT Scalar with this LS6.
    Oct 2007
    983
    I am not sure, I think it would. The temp issue is PCM related.
    Go to engine diagnostics and then airflow, that is where the IAT sensor cal table is located.
    Do you have the latest beta software?
    What PCM and which OS are you using?
    LS1 Tuning Guide
    Sep 2009
    346
    Currently using OS 12592618
    as for the PCM, you know, I have never really understood which version. And dont know how to verify...
    E38? Is there a reference list somewhere?
    I am using the latest beta download.
    VCMSuite-2_23_Beta_12BD_
    25,559,552 bytes in size
    Oct 2007
    983
    It is in the same place as my OS.
    Engine Diag
    Airflow
    IAT Sensor
    LS1 Tuning Guide
    Sep 2009
    346
    Thanks 69Lt1
    You clearly mentioned this in your prior posts, my bad for missing that crucial info.
    Oct 2007
    983
    Glad I could help
    LS1 Tuning Guide
    Tuner Ricardo's Avatar
    Jul 2011
    5000 ft ASL
    79
    I know this is old, but I was not aware of this problem till I started tuning my card maf. Thanks for bringing it up.
    I took some readings today:
    Ambient temp: 62 deg F
    CARD MAF reported IAT: 82 deg F
    When reading your IAT from the MAF you have to start scanning and take the IAT reading inmediately just after switching ignition on. Otherwise the reading will get skewed due to the heat produced by the MAF.
    Will take another reading later on today for reference
    Ricardo
    1996 A4 FBody with LS7 swap
    Nice & thanks for bringing it back up, it never crossed my mind. I just checked a couple of cold start BRAF logs, key on not started.....13*C positive.
    bump on this thread cutting the IAT table by 15% worked like a charm thanks SEARCH function and most importantly the OP
