Results 1 to 20 of 36
Thread: anybody used GM part number 12581687 with an NGK AFX?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    An Impala SS that I had to tune needed to have a bung added for the wideband (it was easier than trying to access the factory O2 sensors for removal). Long story short, the bung ended up destroying the threads on my NTK sensor when all was said and done. I'm pretty sure there's not enough left to salvage the threads with a chaser.
    Having said that, I found that GM part number 12581687 is a cross reference for the NTK 24302 sensor, and it's significantly cheaper from GMPartsDirect.com than it is to buy an "NTK" sensor elsewhere. Has anybody confirmed that it's the same sensor?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    I actually ordered one from there about 2 days ago, so I'll let you know. If I don't post up, bump the thread; I subscribed.
    Steve Williams
    TunedbyFrost.com
    Dec 2008
    on the Dyno
    1,825
    Also interested cause I've only got one sensor currently and if it takes a poo on me I'm screwed for a few day's without a sensor.
    After doing a little research I've come to the conclusion that this is a Saturn V6 oxygen sensor part number that uses a Honda engine. The 2005 Honda Pilot uses the same NTK 24302 sensor that we use for our NGK AFX widebands, even the same plug from my unerstanding. So you can get the GM part number or look up an oxygen sensor for a 05 Honda Pilot at O'Reillys and it brings up Bosch, Delphi, and the NGK 24302. The Delphi o2 sensor is more than likely the GM sensor you guy's found the part number to. I'm not sure if it's a bosch style sensor or if it's an NTK style sensor but for $61.99 I'm willing to find out haha.
    Located in Central Kentucky
    ShorTuning
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    ttt
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Baltimore, Md
    1,213
    ANy update?
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    Jan 2006
    Richmond VA
    1,950
    No, I expected it here (yesterday actually) but still haven't seen it... sometimes UPS is 6:30pm getting here..
    Steve Williams
    TunedbyFrost.com
    Tuner Rhino's Avatar
    Aug 2007
    Olathe, KS
    57
    Due to a bad heater circuit in the sensor that came with my new AFX I've found that Bosch PN 15401 is a direct replacement for the sensor. It comes in a Bosch box, however it is stamped NTK on the sensor itself. It was $98 from the local auto zone.
    Someone else previously mentioned the Saturn V6 sensor. I can't yet verify, however I've been told that Saturn and Cadillac cars both have sensors that will cross reference with this Bosch and run in the high $60 range. I gave the parts guy my bad sensor. He also has an AFX and is trying to find exactly what does work. Hopefully I'll hear back from him this evening.
    Jan 2006
    Richmond VA
    1,950
    Ugh,
    My GMPD order went from processing to 'on order'
    Steve Williams
    TunedbyFrost.com
    Jan 2006
    Richmond VA
    1,950
    ...and it arrived today...
    The sensor commonly used with the AFX is the NTK LZA08-H6
    The sensor from GMPD is the NTK LZA08-H4.
    What is the difference you ask? I don't know. I *DO* have a leaded race car that was dropped off at the shop today, so I may put this to the test tomorrow.
    Steve Williams
    TunedbyFrost.com
    Mar 2008
    St. Louis, MO
    4,860
    It's actually an NTK stamped sensor? Interesting.
    Jan 2006
    Richmond VA
    1,950
    The sensor body*looks* the exact same and the connector is the same.
    It's going to be tomorrow before I get to try it.
    Steve Williams
    TunedbyFrost.com
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    any updates on this?
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Dec 2008
    on the Dyno
    1,825
    Yeah I'd like to see some updates as well cause I'll probably buy 2 of them to keep as backup's when mine finally dies.
    ShorTuning
    bump
    C5-2000 MN6 LS2 block Tony Mamo FAST90+Ported LS2 TB 100mm MAF AFR 205 59cc CompCam 921 Yalla Terra G5X1 LG Pro Headers LG G2+T1 Chassie LG ducts MOVIT brakes - HPT&NGK AFX
    //Sweden
    Aug 2010
    33
    Gentlemen, I am a very large AcDelco distributor and on more than a couple of occasions allowed my NGK rep into my warehouse to open every single part # of AcDelco O2 sensor I have in stock to ID who makes them!!
    Many, many are NGK units and many are Bosch!!!
    Mar 2008
    St. Louis, MO
    4,860
    The real question is whether or not the sensor is the same one that is offered as an upgrade, which is more tolerant and longer lasting.
    Aug 2010
    33
    This is what baffles me....there is no 'better' sensor...depending on what the use is, upstream, downstream,wideband, etc....they all use the same 'head' lets say. The wire length and plugs are the difference.
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by 87gtNOS View Post
    I've always been told the NTK sensor is more tolerant of nitrous and leaded fuel, and lasted longer.
    Aug 2010
    33
    I've always been told the NTK sensor is more tolerant of nitrous and lasted longer.
    NGK vs. Bosch....that I could understand that some 'may' think one is better....
    Mar 2008
    St. Louis, MO
    4,860
    I don't believe it's personal opinion... I am fairly confident that the Bosch sensor gets wrecked under extreme heat or leaded fuel usage.
