I just bought an NGK AFX w/ NTK and installed it on my 2003 Silverado ECSB. This is a low mileage truck (> 50K ), I'm the 2nd owner and I'm almost 100% positive that the tune has not been messed with (except by me ...see below) I've calibrated the sensor free-air for 15 mins. and adjusted the offset in the scanner (not easily done ... but it's within approx .1 afr of the controller readout from what I can eyeball). I'm trying to determine:
1. is the sensor out to lunch or calibration off?
2. are the stock WOT tunes really that rich?
3. Target AFR for WOT? I've read 12.5 - 13... but that info is mostly found on the cars.... would it be richer on the trucks due to weight (conservative tune to prevent knock?) I rarely tow anything, but It's not like I'm at WOT during towing anyway.
The following is just what I have noticed during a road trip this last weekend...I've made no changes to any of the stock timing or fueling....the only changes to the stock tune are related to tire size and some tweaking to shift ponts/pressure:
I was seeing a commanded AFR of ~11:1, measured of ~10.5 - 11:1 depending @ WOT. The targeted AFR at cruise is 14.68 (naturally), and the measured avg's are 14.3 - 14.4 depending on the cell. Is this typical???
Most of what I read has little info on the stock targeted AFR. I'm trying to figure out if this is a typical reading or if I have a sensor that is out to lunch. My inital reaction was that the stock tune wouldn't be that rich... but looking at the commanded it seems like the sensor is probably fine.
Thanks in advance guys for the feedback!
