Ok, I have my LC1 wired up correctly. Thats not the case this time.
When I am key on, not running, my Logworks reads 22.3-22.1 when sitting. My Hptuners reads 21.09-21.0, using the LC1 pid already setup.
I tried using the (volt/.625)+10 and setting my LC1 to read 0v = 10 and 5v = 18, but that just made it worse, HP would say 17.36 while LogWorks still read 22.3.
How do i fix this? I have the offset excel sheet that a member posted up that allows you to plug your actual volts compared to commanded volts.
But I do not know how to command the volts on the LC1. Do you use the Logworks? If so where is it at?
